there is a voice from the front right :)
08.05.2020 19:20 # 1
fatihboz
https://m.youtube.com/watch?feature=youtu.be&v=avccqfrhy54
Hello friends, as I have given in the link, a sound does not start when the engine is cold, it starts after using a bit of harshness. I can't hear it while it is running because of the engine noise, but it sounds like an idle sewing machine. I am waiting for your comments
08.05.2020 19:20 # 2
peugeot murat
Take a picture of the side of the belt I guess your belt looks like a wrongly inserted back or grank pulley sound
08.05.2020 19:20 # 3
fatihboz
I have this voice for the last 2 months :) cekekim birszdn foto
08.05.2020 19:20 # 4
peugeot murat
OK
08.05.2020 19:20 # 5
muhammed.ceyhan
Sir, this is the sound coming from the LPG injectors. Fuck the fuck.
08.05.2020 19:20 # 6
samet206
This is a sound coming from the right side, and in the form of a lighter generally, if this is your problem, the friend you shared the video with has solved the problem in the forum.
08.05.2020 19:20 # 7
muhammed.ceyhan
OK, ask. Actually, it's not the right side. Doesn't it come from red injectors, lpg injectors? This is a normal voice.
08.05.2020 19:20 # 8
fatihboz
Does this sound come in or out, when it comes to gasoline?
08.05.2020 19:20 # 9
peugeot murat
I looked at the video, I took the picture to make sure I saw the belt wrong
08.05.2020 19:20 # 10
fatihboz
I shared the video because it was the same sound, not mine. there is no abnormality in the towing of the car
08.05.2020 19:20 # 11
10URAKAR
Hello friends Big smile
You have referred to my video ... LOL
If it sounds exactly like this, this sound is exactly inside the right hood, there is a petrol tank vent piston connected from the engine part.
Depending on the vehicle's use, this piston used to relieve the pressure created in the gas tank.
In my vehicle, in these 2000 models, this leg is attached to the hard floor, that is, to the inner hood, again with a hard plastic. Therefore, when working at the intervals, the sound spreads incredibly and comes into the cabinet.
I first removed this problem from the hard plastic that this piston was attached to, then I tried to fix the hard cables attached to this piston, I squeezed silicone around it and cut the sound.
I checked this piece in a 2005 model vehicle and I saw that there was a starfor-style fabricated material around this piece so that this problem was experienced and they found their solution.
I would be happy to reply if there is something that cannot be understood, friends. Wink
08.05.2020 19:20 # 12
samet206
The owner of the video has already responded, it is not related to the injector or valve adjustment.
08.05.2020 19:20 # 13
fatihboz
https://m.youtube.com/watch?v=a37mnckqnka&feature=youtu.b to
this is the sound friends from my car
