There is a sound that he starts to squeak while pressing the starter. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:43 | # 1 |
Hello friends; I changed my car's key box last week. I forgot to insert the immobilizer chip & nbsp ;. I pressed the starter 2 times 3-5 seconds & nbsp; the vehicle did not work. Then I inserted the chip & nbsp; worked .. That day is this day & nbsp; When I press the starter, it sounds like it is squeaking & nbsp; the vehicle works like that. I took it to the service & nbsp; He said there is a cost in the starter box, he said 150 TL flan. He said the vehicle is normal at 100 thousand .. Do you think the price is affordable & do I get the correct troubleshooting?
| 08.05.2020 16:43 | # 2 |
[QUOTE = impertore] Hello friends; Last week I changed my car's key box. I forgot to insert the immobilizer chip & nbsp ;. I pressed the starter 2 times 3-5 seconds & nbsp; the vehicle did not work. Then I inserted the chip & nbsp; worked .. That day is this day & nbsp; When I press the starter, it sounds like it is squeaking & nbsp; the vehicle works like that. I took it to the service & nbsp; He said there is a cost in the starter box, he said 150 TL flan. He said the vehicle is normal at 100 thousand. Do you think the price is suitable & nbsp? > & nbsp; It is sure to be from the Mars engine & nbsp; but if it works, I think the vehicle has not so much pain.
| 08.05.2020 16:43 | # 3 |
Exactly 20 - 30 TL said to the piece price.
| 08.05.2020 16:43 | # 4 |
I have the same problem with me. The starter motor needs to be changed.
| 08.05.2020 16:43 | # 5 |
If they say 60-70, people's money comes together with workmanship, but if you say 150tl, 30tl piece is coming too much for people.
| 08.05.2020 16:43 | # 6 |
[QUOTE = hsnsnl] 60-70 people work together with work, but the price of the human comes, but if you say 150tl, 30tl piece is too much for people [/ QUOTE] |
| 08.05.2020 16:43 | # 7 |
keep it this way for her: D
| 08.05.2020 16:43 | # 8 |
cey cey |
service requires a lot of money, I think there are good masters doing this job and ask them to consult & nbsp;
| 08.05.2020 16:43 | # 9 |
[QUOTE = cey cey] service requires a lot of money, I think there are good masters doing this job and ask them to consult & nbsp; [/ QUOTE] If I close it cheaply, I will get it done
| 08.05.2020 16:43 | # 10 |
: D, my master's ears were ringing, and I called the flywheel gear: D
| 08.05.2020 16:43 | # 11 |
[QUOTE = impertore]
Hello friends; I changed my car's key box last week. I forgot to insert the immobilizer chip & nbsp ;. I pressed the starter 2 times 3-5 seconds & nbsp; the vehicle did not work. Then I inserted the chip & nbsp; worked .. That day is this day & nbsp; When I press the starter, it sounds like it is squeaking & nbsp; the vehicle works like that. I took it to the service & nbsp; He said there is a cost in the starter box, he said 150 TL flan. He said the vehicle is normal at 100 thousand .. Do you think the price is suitable & nbsp; or do I make the correct diagnosis? [/ QUOTE] |
| 08.05.2020 16:43 | # 12 |
Wherever this master is or tell us, let's go :)
| 08.05.2020 16:43 | # 13 |
Başakşehir 1st Stage ..: D
