there is a sound like balata sound
08.05.2020 15:48 # 1
alisuat
There is no sound when the car is going, but there is a metal friction sound like a lining sound, even though I do not apply the brakes at slow speeds when passing by other cars or the wall, but there is no difference.
08.05.2020 15:48 # 2
berk2309
If the linings have problems or ate their disks disproportionately, the linings are sprays and dust may escape in the soil.
08.05.2020 15:48 # 3
35kz829
discs are over
08.05.2020 15:48 # 4
alisuat
discs and pads changed 1 year ago 15 thousand or so most dust soil event I have not washed the logical vehicle for 6 months
08.05.2020 15:48 # 5
berk2309
Take my 6 months and what did you do? D is stuck in the top now: D
08.05.2020 15:48 # 6
alisuat
master, you are from Ankara, even I am sitting in proportion, it has been such a winter that I have not been able to wash any time in the last 10 days.
08.05.2020 15:48 # 7
berk2309
Where are you sitting, what is the plate?
08.05.2020 15:48 # 8
35kz829
front rear disks changed at the same time
08.05.2020 15:48 # 9
alisuat
no back in the car that has never changed
08.05.2020 15:48 # 10
alisuat
Let me ask one more question, without the pollution of the subject, my air conditioner does not cool enough, so when I turn it on 4 leaves at 17 degrees, it doesn't let us chill inside. 50 TL, I wonder if I can do it
08.05.2020 15:48 # 11
35kz829
the honeycomb may be very broken and I look at the back disks.
08.05.2020 15:48 # 12
metin
[QUOTE = alisuat] let me ask one more question without pollution, my air conditioner does not cool enough, so even when I open it on 4 leaves at 17 degrees, it didn't cool us inside, the place that installed the pollen filter was 15 or so. 50 TL, I wonder if I can do it [/ QUOTE]
it has nothing to do with it. If it is clogged, no air will enter. it cannot blow because it cannot draw air from outside. In addition, 50 TL came from where it should have been 25 TL. It's also very simple to make money in vain.
08.05.2020 15:48 # 13
Bro what about you, the disc is over, the lining is over ... Is it like that ...
Hodja, clean the bag with a lining cleaner, if necessary, remove the tires so clean. If it does not pass, know that there are small, capillary scratches on the disc, they rub and make noise.
When did you last fill the air conditioner gas for air conditioner?
08.05.2020 15:48 # 14
berk2309
I understood alisuat as if I saw your car: Do not wear the D pads until it surts up and then passes
08.05.2020 15:48 # 15
most likely it is due to lack of gas, check the amount of gas, press it if necessary :)
dust or scratches on the pad often make that sound.
08.05.2020 15:48 # 16
cerci07
the air of the air conditioner is low when it comes to the brakes sound comes from behind or back
If it comes from the front, the possibility of being upright makes the trection in the dissection when the brake is pressed.
If the disc is behind the disc, you can understand by looking at the worn pads.
08.05.2020 15:48 # 17
A different perspective; Could it be the ball sound you call brake sound? Balls can do because they are old or worn.
