There is a problem Help
08.05.2020 14:09 # 1
serkansevil
hi friends 206 I own a car 1.6 I got the vehicle and I wanted to start it. It did not start. No click.
08.05.2020 14:09 # 2
GokhaN
I think the battery
08.05.2020 14:09 # 3
hasimayaz
When you say no click .. doesn't it start? flips, but is there an abduction?
08.05.2020 14:09 # 4
Onur
most likely like a battery
08.05.2020 14:09 # 5
acad
My friend has a look at the battery and the starter engine,
08.05.2020 14:09 # 6
serkansevil
the starter never starts
08.05.2020 14:09 # 7
onderoto
[QUOTE = serkansevil] starter never presses [/ QUOTE]
If there is no movement in the starter when you turn the ignition and the battery lamp on the screen blinks when the starter starts, the problem of the battery in the buttons on the screen and the surroundings come on briefly.
08.05.2020 14:09 # 8
hasimayaz
no reaction on the starter motor ?? no sound?
08.05.2020 14:09 # 9
FTH
If the battery is empty, the vehicle will not start, there is no light on the table.
08.05.2020 14:09 # 10
yigit1989
is either a battery or a battery
08.05.2020 14:09 # 11
elenor
The starter motor, the charger and the battery must be measured with a multimeter in an auto electrician, the electrician will solve the problem, I would appreciate if you write the result.
08.05.2020 14:09 # 12
serkansevil
Thanks guys, the charcoal is finished.
08.05.2020 14:09 # 13
the starter motor is faulty and the starter auto has to be replaced
08.05.2020 14:09 # 14
H-a-d-i
[QUOTE = saklı_prens34] starter motor is faulty and starter automatic needs to be replaced
our friend has solved the problem already, he also stated this. He changed the coal and got the job done.
