There is a gap in the shock absorber
08.05.2020 21:20 # 1
Ersin5252
mrb friends on my 307 car front right shock absorber
I tried to tighten there is a gap in his chock, but it does not
Turns out was I had such a problem before
Ersin5252 2019-10-19 22:21:37
08.05.2020 21:20 # 2
omerb
If I am not mistaken, there would be an allen hole in the upper chock shaft. You will put an allen wrench there and hold it with one hand and prevent the shaft from turning, and with the other hand you will tighten the wedge bolt. I remember it so.
But I think the wedge screw cannot loose by itself. wedge is a rubber material. It can wear out over time.
08.05.2020 21:20 # 3
Ersin5252
the way of the industry appeared, napalim baktircaz
But believe me, even the solid parts are broken.
They say it will change so that the winner wins
08.05.2020 21:20 # 4
omerb
you need to find the right repairman. Even authorized services do rocking work.
Actually, you can handle it. If there is no need to replace parts.
Write a peugeot 307 front amortissor change on Google.
There is a video of 12:45 min. The same model is with your vehicle. You can have an idea.
08.05.2020 21:20 # 5
Ersin5252
thank you master this video was useful I will try
08.05.2020 21:20 # 6
omerb
some mechanical problems can be done by the user if he is handy.
If the tool is complete, of course. The tool works and boasts hands :)
Hope you handle it without much cost.
Good luck with.
08.05.2020 21:20 # 7
If the upper damping bearing is defective, it is best to change the room together with the wedges.
08.05.2020 21:20 # 8
pusutr
+ 308
