There is a gap in the shock absorber
08.05.2020 15:20 # 1
nteker
Mrb friends I took my 2004 model 307 1.6 gasoline vehicle to the authorized service at the weekend, the linings changed. As the linings were changing, we saw the oil on the shock absorbers (i.e. burst), the staff did not say change immediately, I would ask for the price, but I forgot.
My question is, what happens if I drive the vehicle? Is it also a shock absorber in the authorized service? or another shock absorber? I should get.
Thanks for your help in advance.
08.05.2020 15:20 # 2
metin
The original definitely takes the leggings out of the way on the way. Buy from the gaseous ones.
08.05.2020 15:20 # 3
yes, I think the original may not always be the best ...
08.05.2020 15:20 # 4
nteker
I live in Aydın, I don't know if I can find it here, but there are bosh services, how much are their shock absorbers and what is the approximate price?
08.05.2020 15:20 # 5
nteker
If I continue to use it this way, will it happen at least until summer?
08.05.2020 15:20 # 6
If you use the vehicle as such, your grip on the road will decrease, maybe it will make lak lukur sound etc.
08.05.2020 15:20 # 7
nteker
Thanks
08.05.2020 15:20 # 8
metin
[QUOTE = nteker] I live in Aydın, I don't know if I can find it here, but there are bosh services, how much are their shock absorbers and what is the approximate price? [/ QUOTE]
if you don't find bilstein you will find monreo at least better than original. because this hitting sound is in the original, if you change it and get it again, you will have the same problem in the new original because they don't fix this problem.
My master says that we used the shock absorbers of 308, the problem is gone, but as far as I heard from the friends using the 308, the problem continues. stay away from the original shock absorber, especially for those in the back.
08.05.2020 15:20 # 9
nedim83
the same problem came out .. I took my 206 + vehicle to 30000km of maintenance. They said the left front shock absorber is missing the oil but they said it is not something with urgency, they said it will handle until the next maintenance .. they said it is 220TL. I will probably take it out and appreciate it.
08.05.2020 15:20 # 10
sercinho
mrb brother new case i heard that the 307s are better, but you can get another brand if you are not sure of the difference, there is not much price difference.
08.05.2020 15:20 # 11
nteker
I say let it stop until the summer, I'm a little stuck. I definitely write after I change it.
08.05.2020 15:20 # 12
[QUOTE = sercinho] mrb brother new case i heard that the 307s are better, but you can get another brand but if you change the sure, there is no original price difference.
original 65 lira Confused a little cheap for me personally :))
I would have expected it to be more expensive, but I am not asserting it .. should the price be sold to you the original price sold to the original world, a brand's price?
08.05.2020 15:20 # 13
metin
monreo should be between 80-120. not so cheap. There is not that price but not monreo.
08.05.2020 15:20 # 14
nteker
Now I looked at it from otostart.com.
Alltaki Bed Eye-Gas Pressure-Double Pipe- Monroe Original (Gas Technology) ==> 94TL
Alltaki Bed Eye-Gas Pressure-Double Pipe- Monroe Reflex ==> 101TL
08.05.2020 15:20 # 15
metin
I recommend the reflex.
08.05.2020 15:20 # 16
What is the difference of reflex from original
08.05.2020 15:20 # 17
bulent 77
If it is fat, does it mean that it should be broken. Go to a good master first.
08.05.2020 15:20 # 18
metin
As the name suggests, it is safer in terms of road holding in sudden steering turns, while its reflexes are escaped in sudden turns, and its reflexes are strong (:
08.05.2020 15:20 # 19
sahin-peugeot
[QUOTE = CeCoLi] [QUOTE = sercinho] mrb brother new case i heard that the 307s are better, but you can get another brand if you are not sure if you are sure of it, there must be 65 of monroede, then I know that the original one should be 65, monroede o cirirden de cirdirden, it should be 65 comments
List price of original is 115 TL
08.05.2020 15:20 # 20
sercinho
it may not be the original, but I looked at it so I heard that it was this brand in its original
http: //www.***.com/307-amortısor-arka-gazlı-pid-1316.html
Page : / 2
