There are spots on the floor
08.05.2020 20:56 # 1
307XS307
Hello friends. no oil reduction in the car, no water reduction. But the other day, I saw 4-5 glasses of six-sized stains on the floor under the car. I parked in a clean place saying maybe not from my car. I looked the next day, the same spots. what is this?
Note: At least 3 of 4-5 pieces of stains are like dark black oil or paint. the other two are like lighter water. I also looked under the car for a few minutes in detail and could not see anything dripping. I don't know why there are these spots and why
08.05.2020 20:56 # 2
Selcuk55
There may be a sump plug, which may be removed from the gaskets. Wink
08.05.2020 20:56 # 3
307XS307
The place where the stains are is not at the back of the car, but at the front. so the bottom of the car is like the middle of the 2 front tires. even closer to the right tire. Also when I get out of the car from time to time, there is a stench and it disappears immediately. Like the smell of heat. But 1 month ago, there was a water leak from the gasket. water was dripping into the manifold. He did not do water attenuation. I look at the engine oil so there is no shortage
08.05.2020 20:56 # 4
Selcuk55
It is a bit difficult to understand when 1 drop is dropping 1 drop, after half a liter is reduced, it is most likely leaking from the sump plug.
08.05.2020 20:56 # 5
307XS307
the oil has just changed, it's going to be 1 month or so. But as you said, let me go to an intermediate industry. maybe they may not even have squeezed well
08.05.2020 20:56 # 6
RP393
There may be a circulation leak by the right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
When this coolant drips to the ground, it will leave a black stain.
08.05.2020 20:56 # 7
307XS307
[QUOTE = RP393] There may be a recirculation leak by the right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
My teacher was in my mind. and I immediately called the master in the industry. though there is no antifreeze in the car, there is normal water. and I said exactly what they said. He said there would be no obvious stain on the floor if there was a water leak. said maybe there is oil leakage from the cartel
08.05.2020 20:56 # 8
Also, the control of the oil filter cover of our teacher is because our vehicles are plastic and there is a possibility of missing them. Meanwhile, after neglecting to put your vehicle in the car, it starts to face other problems.
08.05.2020 20:56 # 9
RP393
[QUOTE = 307XS307] [QUOTE = RP393] There may be recirculation leakage by right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
If there is no antifreeze, it is true that the master says, it does not leave stains. I thought it might be stained because the antifreeze is oily. As my soner said, it is useful to check the oil filter. Leakage may increase while pumping oil when the engine is running. Or the leak may increase after it gets hot and cool.
08.05.2020 20:56 # 10
RP393
[QUOTE = RP393] [QUOTE = 307XS307] [QUOTE = RP393] There may be recirculation leakage by the right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
If you add antifreeze, do not put red radiator, hose, heater core, circulation gasket piercing from the most sensitive place. Use blue antifreeze. Put antifreeze less than it should be in the first place.
08.05.2020 20:56 # 11
Kysr038
[QUOTE = RP393] [QUOTE = RP393] [QUOTE = 307XS307] [QUOTE = RP393] there may be recirculation leakage by right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
Was it the opposite?
I put blue antifreeze last year, it even flowed into the vehicle. I found the solution with the radiator crack remover liquid.
As far as I can remember from the forum, the red antifreeze was less leakage
08.05.2020 20:56 # 12
RP393
[QUOTE = Kysr038] [QUOTE = RP393] [QUOTE = RP393] [QUOTE = 307XS307] [QUOTE = RP393] can be circulation leakage by right tire. If the dripping liquid is light colored and slippery, it is antifreeze. Start the vehicle, look at the bottom of the fan while it starts to drip, as I said, cooling water.
Red antifreeze is not suitable for engine blocks and other engine components of vehicles under 2010. Especially if antifreeze is not used in the vehicle, it will "pass through" like İbrahim Tatlıses' song. Big smile
Of course, this blue does not mean harmless. Blue antifreeze shows the same effect on a vehicle with dirty water and rust. For this reason, it is useful to practice a well-known blue antifreeze (I use Total, lukoil).
08.05.2020 20:56 # 13
Kysr038
I wasn't sure of my knowledge. In this way, I learned. Thanks & nbsp;
Reviews
Reviews
