The windshield is cracked
08.05.2020 19:12 # 1
fatihiyim
Hello friends 2004 model 307 xt premium
I just joined you
I have a problem with the sensor in the ten windows automatic headlight and wipers
It works abnormally, there is a crack on the glass.
Catlak is not on the outer glass but on the inner side
As far as I have studied gel and pet are used
Before I learned this, I inserted the sensor gel and the sensor
There was nothing like a black gasket between them.
No idea
I searched for clear issues but I couldn't find
I would be glad if you could help
08.05.2020 19:12 # 2
If the full sensor passes through it, it has an effect. Because the sensor works with the rate of reflected and rented light. The sensor has a light source and a photo detector. In the absence of rain, all light coming out of the light source reaches the sensor. If there is rain, since the rain droplet creates a different environment over the glass, it causes some light to escape from the glass and therefore the light intensity perceived by the photodetector decreases. The lower it decreases, the faster the wiper works. Anything that can affect this mechanism prevents the system from working properly. It prevents cracked glass and lack of gel.
08.05.2020 19:12 # 3
fatihiyim
There is no crack on the sensor, my teacher is different
Gel and pad see my name, then thank you very much I also read that the darkened mirror must end up in the green light on the top of the burnt, and there is a solution for it
