The voice I can't figure out where it came from |
| 08.05.2020 16:49 | # 1 |
| 08.05.2020 16:49 | # 2 |
if diesel is suspected before the turbo
| 08.05.2020 16:49 | # 3 |
[QUOTE = toga406] suspect turbo if it was diesel [/ QUOTE] |
| 08.05.2020 16:49 | # 4 |
Sorry. I think we will have more idea if you put the video of the sound. we'll help you. get well soon
| 08.05.2020 16:49 | # 5 |
There is no way I can record that moment, because I am on the move, I need to be very quiet in that voice and traffic. |
| 08.05.2020 16:49 | # 6 |
I can describe it like this, when the gear shifts at low revs, such a forced bolt sounds, a sound that sounds like that. |
| 08.05.2020 16:49 | # 7 |
Cmoss06 |
Check V belt tension ball |
| 08.05.2020 16:49 | # 8 |
[QUOTE = Cmoss06] Check the V belt tension ball |
| 08.05.2020 16:49 | # 9 |
So, when you go in 2nd gear, does this sound when you pull your feet out of the gas and give the gas suddenly? Reviews
| 08.05.2020 16:49 | # 10 |
[QUOTE = koliva] So when you go in 2nd gear, does this sound when you pull your foot out of the gas and give it gas? [/ QUOTE] |
| 08.05.2020 16:49 | # 11 |
[QUOTE = 106fb] I could not fully understand what sound is like. Have you had any changes in your vehicle such as exhaust, catalyst or similar recently? |
| 08.05.2020 16:49 | # 12 |
It did not disappear. A mechanical sound. I think the print came from the pad. Let me describe it as a metal squeak. I did not hear it when I changed the gear of the vehicle at high speed. Only 3000 revolutions & nbsp; and when I change the gear to the lower speed a little bit harder as the car comes out.
| 08.05.2020 16:49 | # 13 |
Can you take a video of this in such a quiet place?
| 08.05.2020 16:49 | # 14 |
But it sounds like it sounds hard on the move and it's hard to catch an instant event.
| 08.05.2020 16:49 | # 15 |
[QUOTE = 106fb] But when the vehicle is on the move, it sounds like it is hard to catch a sound and an instant event. [/ QUOTE] In the first message I said it was happening during the departure. In a way, we need to be able to hear the sound so that we can make healthy comments. Reviews |
| 08.05.2020 16:49 | # 16 |
If I ask the question, then, how many kilometers should the pressure and pad change be in a gasoline vehicle? |
| 08.05.2020 16:49 | # 17 |
It varies according to the usage. It will be between 150 thousand and 100 thousand and 50 thousand.
| 08.05.2020 16:49 | # 18 |
[QUOTE = laedri] Varies according to usage. It will be 150 thousand at 100 thousand at 50 thousand. QUOTE] |
| 08.05.2020 16:49 | # 19 |
SZKR |
If you are in the 1st and 2nd gear, a skinny sound that comes out during the clutch, I am also from the same trouble. Like the sound of rubbing on metal. As I was researching that sound the other day, I grabbed the exhaust by the muffler and heard the same sound. When available, I will lift the vehicle and see if there is anything rubbing in the exhaust line.
| 08.05.2020 16:49 | # 20 |
SZKR |
[QUOTE = 106fb] [QUOTE = laedri] Varies according to usage. It happens at 150 thousand at 100 thousand at 50 thousand .. You can understand from some signs that the printing pad is finished. I think. [/ QUOTE] (By the way, my car is 2003, 1.6xs) |
