The Voice From Garç Gurç When Turning The Steering Wheel? RESOLVED
08.05.2020 20:13 # 1
yigit_dark
Hello everyone;
There is a problem with my vehicle. I noticed the other day. It wasn't a clear sound every day, but today I shot a little more intense video. There is no sound from the undercarriage on the way. I don't think the subset is too bad. There is a sound heard in turns and the sound when we turn the steering wheel to the left. What do you think is the reason for this sound?
[TUBE] ivotuunot2s [/ TUBE]
yigit_dark 2017-06-12 22:23:36
08.05.2020 20:13 # 2
z rods teacher
08.05.2020 20:13 # 3
yigit_dark
[QUOTE = sonerkyl] z rods teacher [/ QUOTE]
Thanks for the answer, the spring or shock absorber came in. I never thought of it.
08.05.2020 20:13 # 4
kadirbap
shock absorber top towers aruzalu
08.05.2020 20:13 # 5
samet206
It is possible in the possibilities that other friends may say on swings. In such cases, showing you to a master who has the opportunity to examine the vehicle will lead you to the clearest solution.
08.05.2020 20:13 # 6
yigit_dark
Sometimes the sound never comes and sometimes it bothers me. The tool I used today with mesa did not have such a sound. Best of all I have a rotbalanscı master, I show him. Those parts need to be changed, then I will repair the vehicle.
08.05.2020 20:13 # 7
sevozgur
Z rot + Shock absorbers seemed to change. Holds 500-600 pounds
08.05.2020 20:13 # 8
yigit_dark
[QUOTE = sevozgur] Z rot + Shock absorbers seemed to change. 500-600 pounds [/ QUOTE]
The problem became obvious. As you said, shock absorbers and shock absorber blocks will change.
08.05.2020 20:13 # 9
yigit_dark
It has been a long time since I opened the subject but my problem has been solved. I said I'll update for him. If he experiences the same problem, he can read and benefit. The left and right Swings have changed in my vehicle. On the part of the swings coming to the wheel, there are rubber and movable parts, they are completely broken. That's why my car is making that sound. I add pictures below. Right now my vehicle was very good, it was hitting it in the laka, that sound was cut. I don't hear any sound from the undercarriage.
08.05.2020 20:13 # 10
hrn 63
how much did it cost hojam ???
08.05.2020 20:13 # 11
yigit_dark
[QUOTE = hrn 63] how much did it cost hojam ??? [/ QUOTE]
I did general maintenance on my vehicle. Let me write the fees I received. Right left z rot changed. Right left Swing changed. Bend iron tires changed. The front and back pad has changed. 4 spark plugs changed. Axle seals have changed. Axle bellows were repaired. The pieces cost 460 in total. I paid 250 lira in labor.
