The vehicle will lie for 5 months, what should I do?
08.05.2020 16:26 # 1
206cc
Dear friends, I am surrendering to the military on Monday, so my vehicle will have to lie down for 5 months, I will deliver the key I know, I will run the vehicle every two weeks a week. It is time to change the oil of the vehicle at the moment, but if I do this now, if I do not have this operation? I couldn't decide yet, I'm waiting for your advice.
08.05.2020 16:26 # 2
06OzGuR06
Take care of your vehicle, let the vehicle sleep like that. Just run it at least 100 km per month. The vehicle will be better. The iron will shine. "Wink"
08.05.2020 16:26 # 3
Ucyuzalti
If the car is going to sleep for as long as I know, the battery's pole & nbsp; head & nbsp; need to disassemble & nbsp;
08.05.2020 16:26 # 4
Ucyuzalti
If your friend & nbsp; if it does not run, you will be on battery & nbsp;
08.05.2020 16:26 # 5
06OzGuR06
Don't get too much sleep, then it will be sleepy then & nbsp; "LOL" & nbsp; Let it travel and not be bored "Big
08.05.2020 16:26 # 6
206cc
vehicle to work from time to time, do I need to disassemble the wheels again, bidet thin sidewall
08.05.2020 16:26 # 7
06OzGuR06
If the vehicle is fully seated, lift the vehicle and put 4 wedges under it. Do not let the car load the tires.
My advice would be better if someone makes a 20 km tour per week without needing them.
06ÖzGüR06 2011-12-07 15:51:07
08.05.2020 16:26 # 8
206cc
if it is logical if i do the maintenance now or if i return?
08.05.2020 16:26 # 9
06OzGuR06
I think it will be better if you do it. Book the maintenance of the filter and when you return, you will use it in a well-maintained way. It is not a short time for 5 months because it is known in the cold.
http://forum.peugeotturkey.com/forum_posts. asp? TID = 18168 & amp; title = search-long-sre-to-sleep your-friends-friends
06ÖZGüR06 2011-12-07 16:10:42
08.05.2020 16:26 # 10
Last year I went to the military and my vehicle was not used for 5 months, I did the following operations. When I returned, I started it in one starter. It is up to you whether to apply it.
1) I disassembled the battery terminal. In order not to oxidize.
2) I lowered the air of the tires a bit. I did not lift the vehicle.
3) I found a parking garage, agreed on the price. I put it 3 times below the ground. Covering the tarpaulin can sweat in the bodywork and cause paint to be exhausted. I would not recommend canvas.
6) I filled the car's gas tank halfway.Fulle if possible. There is no need. I had it done that it was time for maintenance.
9) Have the antifreeze level of the car checked. When you return, check your oil and run it. Let your first job be maintenance.
& nbsp; Goodbye, come and go ..
08.05.2020 16:26 # 11
I had to leave my vehicle before. I left my car alone for 10 months. I had removed the battery terminals. I also listened to my friend's advice and wed the car & nbsp; 4 tires. Because of the hot heat, I did not throw a canvas or something, but you can adjust the cloth and cover it. Though you say that I left it to a friend, let it be used, then it is not only enough to start the engine of the vehicle. I will tell you 10 months later, I pressed the car I wedged into the ground tires. I tied the battery terminals and prayed with a little prayer. Maybe you will not believe it, but took it in one starter and kissed the front hood of the vehicle. I said halal coach, oh ...: D & nbsp;
08.05.2020 16:26 # 12
yavuz25
Put the chock and cut the 4 wheels from the ground, remove the battery and put it in a suitable place at home. "Wink"
08.05.2020 16:26 # 13
djchaos
If your friend is going to take care of the vehicle, get maintenance, grease the terminals and make sure the vehicle travels 25 30 km per week.
08.05.2020 16:26 # 14
Ucyuzalti
In my opinion, do not entrust the car to anyone, take the precaution as the friends say, put it in the closed parking lot, God bless they find the owner of the license if the car crashes while driving the car & nbsp; "C put the car in a beautiful place, it will not be in your mind to rest your car & nbsp;
08.05.2020 16:26 # 15
BurakGONULAL
I am saying my own opinion, selling the vehicle, putting the bank on time deposits, I would evaluate it as a winning money, not a car lying for 5 months :)
08.05.2020 16:26 # 16
206cc
I could not find a closed place around me, the vehicle to stay outside, I will have maintenance, I will take a tarpaulin on it, the vehicle to be run once a week or two, I hope it will not be a problem, I hope I will meet in May
08.05.2020 16:26 # 17
06OzGuR06
We will do the military service, but let's see when "Big May Allah greet with goodness.
The biggest soldier is our soldier "Big
08.05.2020 16:26 # 18
yavuz25
Dude you would regret a tarpaulin puller .;)
08.05.2020 16:26 # 19
Ucyuzalti
Better go to the place where you are going to be a soldier, go to the barracks, tour the car on the market permit & nbsp; "Big "LOL"
08.05.2020 16:26 # 20
yavuz25
There are those who know it. "LOL"
Page : / 3
