the vehicle warns me
08.05.2020 18:50 # 1
sansasyon61
my friends wrote the battery charger fault when I started the car first, and the battery wrote the fault when I started the vehicle, and the abs fault when I pressed the brake, but when I stepped on the brake, there was no problem with the brakes, neither could it cause leakage
08.05.2020 18:50 # 2
sansasyon61
antipollution fault bide this is out :) on the screen, my name and surname did not come out I did not understand this work
08.05.2020 18:50 # 3
sansasyon61
airbag fault is out now
08.05.2020 18:50 # 4
Alicilik
Either he has run out of water or the battery is weakening.
Clean the battery terminals beautifully. Measure your energy and dynamo values.
08.05.2020 18:50 # 5
sansasyon61
Actually, how I say bole while running, the engine is not like singles, it takes the anthem after a few clicks.
08.05.2020 18:50 # 6
Barut
I recently started getting hungry in my car seven starter late. When the battery got a dead one, it got better.
08.05.2020 18:50 # 7
sansasyon61
luckily I will not go to the master in the market industry tomorrow.
08.05.2020 18:50 # 8
Barut
[QUOTE = sensation61] luckily I will not go to the master in the market industry tomorrow, do I get a problem?
08.05.2020 18:50 # 9
okan77
The battery terminals are oxidized or the battery is weak ... Usually, battery problems arise with the cooling of the weather ... I think there is nothing to be afraid of. The problem appears on the battery.
08.05.2020 18:50 # 10
sansasyon61
I was a master, so let me show you to the electrician today as the first job works in the morning car :)
08.05.2020 18:50 # 11
sansasyon61
The problem has been solved, the reason for the completion of the battery life is the battery, the pearl battery is 60, I put it on, and the warning signs are gone, thank you everyone.
08.05.2020 18:50 # 12
Barut
[QUOTE = sensation61] the problem has been solved, the reason is that the battery has completed its lifetime, the battery is 60 th pearl battery as a battery, I put it on and the tu warning signs are gone. How much did you get the battery? I guess they were piling me.
08.05.2020 18:50 # 13
Genc12
Sir, battery or sarzo dynamo. You have to check
08.05.2020 18:50 # 14
nevce
get well .. but if he does it again ....
http://forum.peugeotturkey.com/forum_posts.asp?tıd=36612&title=307-airbag-fault-abs-fault-brake-fault-sorunu-coz
sort of 2014-10-13 22:02:03
08.05.2020 18:50 # 15
sansasyon61
My master put the battery on 130 TL, I don't know if the price is normal or not :)
08.05.2020 18:50 # 16
Barut
[QUOTE = sensation61] Master, I put the battery on 130 TL, I don't know if the price is normal or not:) [/ QUOTE] I mean 160 I mean they have a fluent agreement with our electricity :)
08.05.2020 18:50 # 17
sansasyon61
I am not a mercy in the nation :)
