The vehicle suddenly started not starting
08.05.2020 17:55 # 1
baroff
hello friends when I parked on the sidewalk of the house 30 minutes ago when I was working, I said I will run it after I parked the car on the sidewalk, I do not think that the battery will be from him anyway, what do you think the problem might be? My neighbor said it might have been something from the starter motor cable if you were either fused or undressed? Why do you think I can find if the starter cable is not in the cable or what can I do if it is fuse?
08.05.2020 17:55 # 2
Give it a try with a spare key.
08.05.2020 17:55 # 3
error
If you don't hear a signal when you bring the key closer to the ignition, try the koliva master's suggestion, but if the spare key does not work, the starter motor might be out of coal. Check it out. Check the fuses.
Slide the vehicle by half a meter while in gear and try again, if the problem is coal, it can work like this.
error 2013-09-01 18:38:34
08.05.2020 17:55 # 4
baroff
[QUOTE = koliva] Try it with a spare key.
the result I tried is the same. I wonder if it can be from imobilizer?
08.05.2020 17:55 # 5
baroff
[QUOTE = error]
How exactly can I do it, hodja?
BAROFF 2013-09-01 18:50:59
08.05.2020 17:55 # 6
fatih__bass
For 307, when the vehicle temperature exceeded 90, the starter did not start, and when it cools down, it was returning to normal.
08.05.2020 17:55 # 7
baroff
[QUOTE = fatih__bass] For 307, when the vehicle temperature exceeded 90, the starter did not start, it returned to normal when it cools down.
the room could be hod, my friend had a hospital job I made 120-140 km of the vehicle, the 90th temperature trip, fan did not turn on or something diode
08.05.2020 17:55 # 8
error
What I meant was that the baroff could cause the vehicle's starter motor to turn a little, so that it could be temporarily removed if there was contactless coal.
push a little while the vehicle is in gear 1 and then try to start again and check if the vehicle has an inoperative electronic part.
08.05.2020 17:55 # 9
error
When he says that he did not get a starter, does the starter motor spin or does not start or there is no movement?
08.05.2020 17:55 # 10
tilbe307
If there is a clicking sound when turning the starter, there are two reasons, whether the starter motor or starter charcoal has passed
08.05.2020 17:55 # 11
baroff
The starter motor never rotates. I turned on the headlights or something, I started the starter, click it, empty click sound sounds like that A master for starter coal said that when the headlights were on, the lamps on the dial would go off a little. Is it possible to be from the battery? Toxicity or something.
08.05.2020 17:55 # 12
error
Well, the things you told me came a month ago, a service that I left my car had pilgrimed the new battery and replaced it with an empty battery.
Try it with a supplement, let's see if I will start
error 2013-09-01 23:45:15
08.05.2020 17:55 # 13
baroff
Just like an experience building battery reinforcement, coal does not bother. Thanks a lot for your help.
08.05.2020 17:55 # 14
yenice
Firstly, get well soon. I hope it is because of coal. because it happened to me too, I think I didn't remember whether I gave 4 coal or 5 lira :) I did not press the starter at all. We hit the car, started it, then stopped it and pressed it again. I tried this a few times and it worked. I rested the car for a while and pressed it again. the same thing happened the next morning. We looked at the coals are finished, we changed the problem has improved. but the starter motor is in a very weak place. we tried a little to disassemble
08.05.2020 17:55 # 15
baroff
Thank you. They make starter coal around 100-150, which is exactly my free time. Would it be a problem to have my vehicle hit diesel? BAROFF 2013-09-02 00:38:41
08.05.2020 17:55 # 16
yenice
[QUOTE = baroff] Thank you. They make starter coal around 100-150, which is exactly my free time. Would it be a problem to hit my car diesel too? [/ QUOTE]
I think 100 - 150 lira is a huge figure. For 206 renault starter coals fit. they are type. I do not remember the price, as 5 6 months have passed. I gave 4 of them something like 5 - 10 liras. After the starter had already been removed, it was not very detailed for the coal to settle. a little trouble to disassemble. I remember that I gave 25 lira for workmanship. 150 lira is really high. I think do some research.
08.05.2020 17:55 # 17
baroff
[QUOTE = yenice] [QUOTE = baroff] Thank you. They make starter coal around 100-150, which is exactly my free time. Would it be a problem to hit my car diesel too? [/ QUOTE]
I looked over the internet, it is not too expensive, coal is 5 liras, the jackals are 10 liras.
08.05.2020 17:55 # 18
baroff
I think the problem is that the lamps from the battery were on yesterday, and today they are not lit, but there are no signs on the dial. I think it will be done with reinforcement. Hopefully, dynamo does not cause any problems.
08.05.2020 17:55 # 19
error
battery dead
08.05.2020 17:55 # 20
baroff
http://www.boschakuistanbul.com/images/content/big/1354611655.jpg
I have this battery, but I never know where to look at the level of fullness. If it is empty, I will take it out to where I bought it.
Page : / 2
