the vehicle stops when you take your foot off the gas at the first start
08.05.2020 13:58 # 1
FIRAT
hello friends 2000 model 206 xr 14 I have a problem in my automatic car yesterday evening, as you know, in automatic vehicles when the gear is in the parking position, we start the vehicle by pressing the brake without giving gas, when I do the same operation last night, the car ignites but it was not working. vehicle is stopping I suspect injector and carburetor blockage Any other idea?
08.05.2020 13:58 # 2
We need to connect the injectors to the test, but if the engine is running when it is hot, it works if it runs smoothly at idle.
08.05.2020 13:58 # 3
hasimayaz
The oxygen sensor comes to my mind first.
08.05.2020 13:58 # 4
FIRAT
Serhat brother, I was hoping to get around with a little gasoline in the car for a few days. When I pull my foot out of the gas, the car stops, so I cannot move it, I do not get gasoline to the engine. Spark plugs changed 6 months ago
08.05.2020 13:58 # 5
the injector won't be clean, if yours is clogged, we'll put them into the test, and if the car stops, when you pull your foot, it means the engine is coming, you need to be connected to the machine.
08.05.2020 13:58 # 6
I spoke to the master right now, saying that it is an idle valve, the butterfly throat will be cleaned and the idle valve will be checked ...
08.05.2020 13:58 # 7
HakanGokdemir
Here is the PeugeotTurkey difference, full support instantly and unrequited ...
08.05.2020 13:58 # 8
FIRAT
I can't move the car so that we have to pull the foot out of the gas to bring `` D '' into gear, when the car pulls out of the gas, the vehicle stops, so how can we move it?
08.05.2020 13:58 # 9
press brake with your left foot
If you have a motor vehicle
http://forum.peugeotturkey.com/forum_posts.asp?tıd=379
08.05.2020 13:58 # 10
sinan-s
It can be from oxygen sensor or throttle ..
08.05.2020 13:58 # 11
haruncoskun
there may be a problem with the idle setting
08.05.2020 13:58 # 12
gokan
idling sensor ... engine was never rinsed
08.05.2020 13:58 # 13
FIRAT
Thanks for the opinions, friends, I tried to start the vehicle again in the evening and it worked smoothly, but I still need to be cautious as soon as I look at the idle valve, where I will clean the throat, the injector.
08.05.2020 13:58 # 14
EMRE
parking sensors do not work, if I remove it, there will be holes there, I thought to paint how do I paint the sensors myself, how do I need to paint with a paint, do I need a primer or spray paint work?
