The vehicle starts sometimes it works sometimes it doesn't
15.07.2023 16:32 # 1
emree52
Hello friends. My car is a 2002 1.6 xt model gasoline LPG Li. When I turn the ignition and start it, sometimes it starts at once and sometimes it starts 3-4 times and it seems like it will start completely. When I press the gas pedal, it doesn't start and stops. If I press the gas pedal and get gas, it starts normally. Can anyone help me if this has happened to you? Thank you in advance emree522023-07-15 16:33:57
16.07.2023 17:33 # 2
CanK_106
Hello, how old is your car's battery? I had the same problem, and after changing the battery, the problem went away.
16.07.2023 18:13 # 3
emree52
Hello, thank you. First of all, let me measure the battery. The car starts when it gets gas, sometimes I think it's fully started, but it stops. At first, it could be the battery, as you said, I can smell gasoline when it starts. I just changed the spark plugs. I was told that it could be the crank sensor or the injectors. I will have it checked this week. emree522023-07-16 18:13:47
16.07.2023 20:55 # 4
CanK_106
I understand, you're welcome, have a good evening.
18.12.2023 22:04 # 5
LORD01
I have the same problem sir. Did you solve your problem?
