The vehicle shakes, stutters
29.09.2020 23:19 # 1
Recepkuzey
Hello, I'm new to the forum, I just bought it in my car.
29.09.2020 23:41 # 2
ismailkaya
What is the brand and model engine type of the vehicle.
30.09.2020 09:43 # 3
x571
[QUOTE = Recepkuzey] Hello, I'm new to the forum, I just bought my car, my car stalls, it stalls, it works very irregularly, it bounces and bounces on the way, they said that the ignition is relevant in the failure record, the original spark plug was installed, it still did not improve. / QUOTE] some original as installed coils do not fit. it happened to me. it did worse than the broken coil. i got delphi it was good. It would be better if you take it somewhere with the original software, but they call everything from butterfly, you do, nothing changes.
30.09.2020 14:10 # 4
Recepkuzey
My teacher, Delphi was attached to me.
30.09.2020 14:11 # 5
Recepkuzey
How did you solve it, teacher?
30.09.2020 14:13 # 6
Recepkuzey
Pejo 207 1.4 gasoline teacher
30.09.2020 16:57 # 7
ismailkaya
1.4 16 v 75 or 90 lik
30.09.2020 17:02 # 8
ismailkaya
Not every mechanic can easily figure out which city do you live in
30.09.2020 22:27 # 9
Recepkuzey
1.4 My 8valf teacher, I live in Istanbul Sultangazi. Do you have any master close here?
30.09.2020 22:36 # 10
talip206
Sounds like coil failure to me too. Of course, the problem may not be the direct coil itself. You can examine the cables coming to the coil backwards.
01.10.2020 00:30 # 11
Recepkuzey
The coil has changed, sir, with the original one, let's see the oxygen sensor and the throttle, I doubt you.
01.10.2020 11:45 # 12
ismailkaya
Unplug the oxygen sensors, if the vehicle has LPG for both of them, use LPG to see if there will be an improvement.
01.10.2020 15:46 # 13
Recepkuzey
LPG also does the same thing but teacher, where can we pull the plugs of the sensors?
01.10.2020 16:05 # 14
Recepkuzey
If I unplug the oxygen sensor and use it, would it cause a bigger error?
02.10.2020 14:57 # 15
ismailkaya
You wrote that your vehicle is running irregularly. Is there an idle fluctuation?
