The vehicle runs late in the mornings
30.11.2020 20:49 # 1
Karaman
Friends, first of all, good evening to everyone and my Lord, who conveys this corona, bless us all. And let those who are caught with this message give immediate healing. My question is; Pejo partner works very late in 2007 model mornings. I don't know if the engine is warming during the day, it doesn't cause any trouble. There was a malfunction in the glow plugs, we replaced 4 of them, the same problem. Could it be from the crank sensor. Or does anyone have any idea about it. Thank you.
01.12.2020 08:50 # 2
Hello my teacher. May my Lord heal everyone. When it comes to the trouble you said, there are a few options, as you said, the crank sensor can be. It can also be from a diesel filter. the second option is in fuel pipes etc. may be on the run.
01.12.2020 13:13 # 3
Karaman
10.000 km maintenance is done regularly. Diesel filter is renewed every time
01.12.2020 14:34 # 4
talip206
Crank sensor failure usually occurs when the engine is hot. But it is useful to check. I think the problem is in the diesel recycling line. It could be slipping back.
03.12.2020 22:33 # 5
Orcun.Dmr
Is the relay of the glow plugs checked?
03.12.2020 22:36 # 6
Karaman
Yeah. It was done in role control. works.
04.12.2020 23:29 # 7
bursae16
Hello good forums. You said that the glow plugs have changed. Let me explain a few things that could cause. First, the use of poor quality diesel plays an important role in cold starting. If you buy cheap diesel, there may be starter inefficiency due to the institutions in it. Second, and if you are experiencing a dead starter, the main cause that can be a problem is your starter. You can understand this with small tests such as the flickering of the headlights when you are operating any electrical components such as an automatic window with the ignition and headlights on, or when you touch a very light gas at idle. If you have these, you should change the coals of your starter and, if necessary, the windings. As I said, if cheap diesel is added to this situation, the dead starter will be inevitable. Good forums ..
05.12.2020 12:46 # 8
Karaman
Hello master. Starter dynamo caused by beating and starting was done 2 times. We have been using opetten as a bidet fuel for years. But yesterday morning we poured some hot water on the diesel pump before starting it up. It worked after a few starts. Probably there is a problem with the diesel pump. They will dismantle the pumper during the week.
10.12.2020 20:49 # 9
benzersiz35
If my brother is working immediately when he has to work late with anthem in the morning, it is not any of the above. It is not the case of dodging diesel. It does it from the diesel pump. Also, the glow plugs make such a malfunction. The spark plugs are intact, but if the voltage is coming to the spark plugs, they are very important and small details. I wish you respectq
16.12.2020 21:58 # 10
Karaman
Hello friends. We changed the diesel filter set yesterday regarding the problem of working late in the morning of our vehicle. But the trouble has not been resolved again. Today, we disassembled the diesel pump and injectors and gave them to the pump.
16.12.2020 22:46 # 11
Outlander
Get well soon. My vehicle is 2003 2.0 hdi Partner. Sometimes I do it in the morning. First starter does not run. But the second one works as a sure click. I'm following the subject. I hope your problem can be solved with a simple intervention.
18.12.2020 11:48 # 12
benzersiz35
PROBLEM SOLVED Yesterday morning, I had the diesel pump look at it and said, `` I'll try to get it out of trouble. Master and yesterday I bought my vehicle. mazot.pompasindanmis boredom paid 1100 tl now working in quarter starter now.
22.12.2020 14:02 # 13
Karaman
Hello guys again. The car is related to our problem of working late in the mornings. The diesel filter set has changed and the diesel pump has been overhauled and the injectors are in good condition. Only 2 incontinence was detected in the valve. How do you think I should go. Respects
16.02.2021 01:36 # 14
Karaman
Hello friends. Because I haven't been able to join the internet for a long time
I have to inform you about our vehicle breakdown with a delay. It was refined. And all the parts were used in known brands with the recommendation of the grinder. No parts that could be a sub-industry were used. And I do not recommend using sub-industry parts in such brands.
Our engine has been made. We received it. For now, the trouble has been resolved in this way.
Thank you to everyone who supported us in the forum and guided us with their ideas
. Best regards ...
11.03.2021 22:35 # 15
Nail46
Hello, I had the same problem.
Fuel pressure sensor Changed No problem.
21.11.2021 16:54 # 16
luckylukegs
I'm a partner of 1.9 d 2005 friends. I've been having the problem of not starting this morning for a long time and it didn't work no matter what we did. The car starts very hard at the first start in the morning. I can start it after manually pumping diesel. I think there is a problem of fuel leaking back. It works by misfire. The car is constantly trying to stop. However, after 4-5 minutes, there is no problem in the car. I don't have any problems during the day. Until I start it again the next day. I had a check valve installed. I changed the advance sensor. We replaced the valves, the problem is the same.
I would appreciate it if anyone has experienced this problem and solved it, if anyone can help
21.11.2021 22:37 # 17
AdemUsta1
Hello, if you are around the Anatolian side of Istanbul, bring the vehicle and diagnose it, if you want to contact me, just reply my message here, I wish you a good day :)
