The vehicle malfunctions all functions at the same time
08.05.2020 21:07 # 1
emrermis
hi friends 2006 407 2.0 automatic lpg 170 thousand km, my car suddenly found itself in strange malfunctions with no problem. I parked the car in the evening, there was nothing, I was running it in the morning, waiting for it to warm up, the headlights were on, they started flashing like flashing, they are accelerating and stopping, the display shows PRND failure, but there is no problem with gear shifting. The wipers operate spontaneously after 3-5 minutes at 1 tap speed and do not interfere in any way, do not stand, pass to another level, or provide glass water. Although the air conditioner / heater is on, it stops completely. The horn does not work. There is no intervention to the headlights. But the tape works smoothly. These sometimes start within 2-3 km, sometimes within 100-200 meters, then suddenly everything gets better then starts again, a strange fault. When the wipers fail, I stop the car and the doors do not stop in my mass. When the battery is disconnected and plugged in, everything turns normally and when it goes a bit, everything fails again. When I took it to the electrician, the fuse box was faulty, he said that when we found that we couldn't find a new box, he couldn't get it because he wanted a price over 1000TL, he repaired the fuse box at that moment, master, but again, nothing changed, he said. What do you think is the reason for this malfunction? By the way, the vehicle has premium model lens headlights, white lights, I think it is zenon, but I know it is the original version.
08.05.2020 21:07 # 2
GokhaN
You first show the vehicle to a cerebellum. In Fatih, Fatih Sultan Mehmet had a brain man in the industry. He had to tell him to take a look.
08.05.2020 21:07 # 3
emrermis
I also showed the vehicle on 3 different masters, the insurance table will change. The funny thing is that we couldn't find an insurance table in the big industry. There are places on the internet that want 1300tl to zero.
08.05.2020 21:07 # 4
emrermis
friends problem solved. All the problem was caused by the xenon, when I got the car there was the xenon, I thought it was the original but it was made later. In almost all of the 407s, this xenon event is causing trouble. When I showed the problem to many masters, it was said that the fuse box will change, but I couldn't get it because we couldn't find the box, after a while, the left headlight went out, it went away with faults, and when I turned to this headlight case and researched, it turned out that the event was caused by zenon. Fortunately I noticed the wiper motor without burning it, otherwise there would be a nice cost for me
08.05.2020 21:07 # 5
27BEN80
get past, the parts added to the vehicles later cause these troubles
08.05.2020 21:07 # 6
emrermis
the malfunction repeated again, the problem was not from the xenon. We already noticed that the zenons were not inserted afterwards. Today, we tried 6-7 fuse boxes in the industry, it has not been corrected, we have repaired our own box, will we repair it? I did not understand what kind of malfunction, prnd shows transmission malfunction, the car is connected to the computer on the screen, the malfunction is not visible, we took it to the gearbox, looked at the computer connected to the computer, there was no malfunction in it, there is no problem in the gearbox or something on departure. Wherever this malfunction is caused, I will share it if I can find a solution that affected everything. It started to cool me from my car that I love so much.
08.05.2020 21:07 # 7
My teacher is likely to have a short circuit in one of the electric cables and check the electrical chassis connections of the vehicle.
08.05.2020 21:07 # 8
Murat01
Bsi brain malfunction this happened to me also changed in the service exiting 1500tl expense gone 6 months guaranteed
08.05.2020 21:07 # 9
ismailkaya
Go to a good electrician and have a problem like that.
08.05.2020 21:07 # 10
atasen
In 2004 model 307, the malfunction of the audio brand mp3 player (sdcard, usb stick, aux in input box) that I had installed and used for 6 years without any problems caused this kind of problem. until you realize this;
in a peugeot master who is well known in the gardening industry,
they changed the connector, what it was, sir, overfeeding.
when something hasn't changed: the old connector has over-fed the brain. or it may have had a short circuit with water in the brain. you have to look at the brain. Price? It may be between 500-1500, but not a certain one ...
I did not make them, I found a brainbender in yenibosna :-) electrician, they installed a brain that they were sure was okay, the problem is the same, they changed the instrument panel, the problem is the same. eventually they noticed the mp3 player I mentioned, the problem was solved when I removed it.
08.05.2020 21:07 # 11
emrermis
For now, I have understood that there is no fuse box for the cerebellum. Bsi is there a chassis to look at his brain? If the problem is resolved, what will I write here again?
08.05.2020 21:07 # 12
Crayzmetin
I quit [QUOTE = emrermis] and we realized that there was no fuse box in the brain for the moment. Bsi is there a chassis to look at his brain? If the problem is resolved, what am I going to write here again? [/ QUOTE]
When I first read it, I said certain xenon, then I removed it when I said I removed the xenon but after changing them, you put on led xenon. I have personally read that in some places the bsi brain is confused with led bulbs and cause problems in the vehicle. As Facebook and Whatsapp group, I was disturbed by the yellow bulbs of the vehicle and I said that I would get a led xenon. I did not get it installed because the leds installed with poor quality will burn the wiper motor in the vehicle and cause different malfunctions. Instead of these, I look at the bulbs that give halogen osram 130 more than warm.
I recommend you turn the headlights into a normal bulb and test for a while. It is the least costly method you will try for now. You won't lose anything. I heard about those who complained about LEDs. But interestingly, I heard people who did not experience problems, but the number of them is much, much less.
08.05.2020 21:07 # 13
Crayzmetin
By the way, the person I bought told me that I had xenon in the original of the car after the accident, stealing xenon was inserted and after that the car burned his brain and turned back to the yellow bulb.
08.05.2020 21:07 # 14
ismailkaya
I am very curious, where do they find the fault?
08.05.2020 21:07 # 15
emrermis
I think the car has finally improved. The problem came out of the coil. We bought the bounce fuse box and coil that broke the coil breakdown and damage the brain in the damage fuse box and the tool and the bsi were repaired in the brain.
In the empty space, I dismantled the zones of the vehicle and got the small box like the led lactic xenon bulbs and two red lamp holders. However, my gearbox position sensor is my position arm, the room was malfunctioning, but I did not get prnd malfunction on the screen because of the budget, but there is no physical problem with the gearbox.
The cost of this malfunction cost me 1100tl and it cost 400tl to disassemble the zones.
Bsi brain repaired
Output fuse box installed
Output coil installed
Transition from Zenon to lede
Total 1600tl.
In addition, I replaced the trunk shock absorbers and put 20-76 molds on the shock absorbers. Buda 50tl 2tane shock absorber, 28tl blue mold spring kept price, I installed it myself, has a simple assembly. I have learned a lot about 407 and if you have questions, I try to help as much as I can.
By the way, would I pay if I wanted to sell the zenon bulbs and their senses?
