the vehicle is pulling right !!
08.05.2020 15:11 # 1
canmurat666
Hello friends, I will ask you for help.I have 206 xs when the car is right on the throttle, the car pulls to the right, I got the master, changed the undercarriage, but still continues to pull.
08.05.2020 15:11 # 2
peugeotefe
look at the right axle. Have the swings changed? When I press the gas and pull the foot off the gas, do I dive?
08.05.2020 15:11 # 3
dadalvas
I have 206 colorlines in 2002, when I press the gas to the left, I pull it to the right. For the third time, I'm taking it for repair. The problem has not been solved.
08.05.2020 15:11 # 4
Serhun
Rod adjustment tire diameter, tire tread shape and tread width (front tires must be exactly the same) and pressure, swing, bushings, ball joints, engine and transmission wedge are factors that cause such problems.
Good luck with. If you have read up to this point, we expect a meeting piece from you.
08.05.2020 15:11 # 5
mdincer34
I have the same problem in the vehicle, unfortunately, the front team was zero, but I think I was able to understand the problem by replacing the tires from the tires.
