the vehicle is not going to help
08.05.2020 16:24 # 1
by_imp
Hello friends, I have a small problem, I would be glad if you help me, the problem is that my vehicle is noticeable and noticeable when I travel in the normal course. If I couldn't hold the vehicle after 3 thousand cycles before, now, just like diesel, it was getting cumbersome, it is getting faster, the old waste leak plugs have changed, only 3 nail plugs were installed.
08.05.2020 16:24 # 2
djchaos
Have you looked at the air filter, have you checked the gaskets? oxygen sensor can also do not exceed certain cycle, Catalysts & nbsp; can be clogged Do you have a lpg? A friend who understands from 106 will help
08.05.2020 16:24 # 3
by_imp
No lpg teacher today I took this car 3 3 years old mechanic with old spark plugs, this was a problem.
08.05.2020 16:24 # 4
Ucyuzalti
Look at the brakes and tighten
08.05.2020 16:24 # 5
by_imp
I don't think my brother is going to idle because there is no holding because
08.05.2020 16:24 # 6
06OzGuR06
Manifolds & nbsp; It may not be clogged, although it is not very common with gasoline.
08.05.2020 16:24 # 7
by_imp
I mean the gas pump, the penzine pump is also installed big 6.5 bar, there should be 3 or 3.5 or so something on the original
08.05.2020 16:24 # 8
by_imp
guncel
08.05.2020 16:24 # 9
by_imp
again current
08.05.2020 16:24 # 10
MagicPerformance
Are you in Istanbul ?
08.05.2020 16:24 # 11
by_imp
Unfortunately, my friend gaziantepte'm screwed to in town on the 106`n rare RISK is especially a GTi series of fingers sayildig the old one in town turkiyenin 3.M the 4.M the old one in town having a large industrial-size one in town that during the first week will be based on that arabayi computers in big industrial place aradim size to an in town that I couldn't find a place to attach the car in that big industry :(
it was a bit like poetry :)
08.05.2020 16:24 # 12
peugeotefe
Is there any problem with the gas eating of the car, does my friend say that he never leaves?
08.05.2020 16:24 # 13
MagicPerformance
Rebel gti`cı :)
Boredom It may be from the throttle, they remove it and clean it, does the vehicle turn on the malfunction lamp?
08.05.2020 16:24 # 14
by_imp
no light does not burn gas breakdown so when the first engine starts there is a 3 5 second cut, after that I got a trouble no vehicle got it was there it was very clear while going on the straight road for 1 month while the gas is fixed between 70 and 90, it has a very clear waist, as if I knew that there is something that keeps the car and leaves as much as I know. There is a way to hold it down.
When you forget to take the handbrake and try to get up, ten tries to get up, the back is either a clear feeling when I get up to speed.
08.05.2020 16:24 # 15
MagicPerformance
I do this on a routine basis, otherwise & nbsp; occasional queue?
08.05.2020 16:24 # 16
peugeotefe
There is a problem with your car's gas pump or injectors, man, you should have them look at it.
08.05.2020 16:24 # 17
by_imp
no it does it all the time when the engine is cold I feel more like
I add water to both of them. .
2 sometimes, when it comes to equilibrium at the idle, I don't eat gas, I press the gas.
08.05.2020 16:24 # 18
by_imp
[QUOTE = peugeotefe] There is a problem with your car's gas pump or injector, man, you should have them look at it. I didn't get it done because it came out
08.05.2020 16:24 # 19
MagicPerformance
[QUOTE = by_imp] [QUOTE = peugeotefe] There is a problem with your car's gas pump or injectors, man, you should have them look at it. And if this event is done when the petrol is in the quarter tank or below, the gas pump is definitely defective when I put it into service last night. [/ QUOTE]
I did not get it done because it costs around 2000 TL [/ QUOTE]
you already know the problem why are you making us paw: D
08.05.2020 16:24 # 20
peugeotefe
The fault is already in the middle, you know it yourself
Page : / 2
