The vehicle does not exceed 3000 cycles
08.05.2020 21:11 # 1
darkiron
Have a nice day,
Our 2006 307 1.6 HDI 110 vehicle does not exceed 3000 cycles. The master in the industry has said that there is EGR valve blockage. If it changes, there will be a cost of 1200 TL. Is it possible for us to clear this out or is there another problem?
08.05.2020 21:11 # 2
It's being cleaned, bro. Of course, if it is blocked, it also makes a turbo electrovan.
08.05.2020 21:11 # 3
darkiron
[QUOTE = sonerkyl] is being cleaned, bro. Of course, if it is blocked, it also makes a turbo electrovan. [/ QUOTE]
Hodja, I have read from old subjects and we will have a look that looks like a turbo electrovan. They say that the turbo is protecting itself because it presses high pressure.
the darkiron 2019-03-11 09:32:12
08.05.2020 21:11 # 4
darkiron
I came back about 1 year later :) We have done 210,000 maintenance to the vehicle in the past weeks. All fluids have changed, except transmission oil and brake fluid. In addition, the Timing apricot and recirculation pump, the front brake disc and pad, the rear brake only changed the pad, there is now an event called turbo overboost as you know. who knows already will not explain. Traction of the vehicle was low. We went to the master and the master said that it might be from egr electrovan, he removed the egr and cleaned it (it wasn't dirty anyway). previously it was malfunctioning from the solenoid valve, but traction is still low. It feels like the turbo doesn't pressurize officially. what could be the reason for this vehicle revolves, not just power. The malfunction does not turn on the light either, but one has to look at a computer. I'm waiting for your help :) the darkiron 2020-02-18 18:59:08
08.05.2020 21:11 # 5
EmSul
I guess the turbo clutch should not be over 3000 rpm, but I think that was the old subject
A turbo pressure should be checked for traction low, and you can cancel and try egr
08.05.2020 21:11 # 6
darkiron
The master looked at the turbo, listened to it, but said there was no problem with the turbo. I think I need to take another for EGR
