The tool no longer works
08.05.2020 16:16 # 1
muntehaozen
Hello, brothers and sisters,
I'm telling you about my 2004 model 307 xt petrol and scuba & nbsp; my car had a nervous breakdown. -10 minutes it was working when I rested.This problem started to get more frequent and it stopped working when I rested. & Nbsp; it was not working. / div>
They said spark plugs. I changed them. cost (trigeri, discs, oil water is here)
There is half tank gas, half tank gas in the vehicle, but the stomach is not working. I heard it while I was thinking it was the last spark plugs condensation. I said it would put the computer into the tool but I do not want to be ignorant about it.
08.05.2020 16:16 # 2
peugeotefe
If the starter is not working and the car is not working, ignition and fuel may be a problem.
08.05.2020 16:16 # 3
I do not know the full address and phone number, but there is a master. Auto hawk Huseyin wrestler. Mercedes master but no car he does not understand. If he sees the vehicle, he does not need to open and look. I describe the place with a private message.
08.05.2020 16:16 # 4
You have the right to take back the cost of the parts you have replaced at the authorized service when they cannot resolve your defect by return & nbsp;
08.05.2020 16:16 # 5
muntehaozen
And I'm worried about this is an expensive piece, as you know is it possible to be a catalyst?
08.05.2020 16:16 # 6
I think there is an electronic problem with this vehicle. Could you have the vehicle's medicine checked? I say it would be very good if it could be tried with a different ecu ...
& nbsp;
307 of what I knew before was stopping when we were not. Often, the problem they checked came out of the ECU. Of course there will be the same situation. But it reminded me of this situation ...
CeCoLi 2011-10-20 00:56:29
08.05.2020 16:16 # 7
rifatseker
This fault reminds me of crank sensor failure. It looks very similar to the problems I had with my previous vehicle. It is useful to have it checked. Even if the sensor is intact or replaced, it is necessary to check the cable harness in which the sensor is attached. rifatseker 2011-10-20 08:53:15
08.05.2020 16:16 # 8
eserxxx
I had a 206 owner five years ago. The same problem existed in that vehicle. I had a solid master back then, we pulled the car to him and the immobilizer said there was a problem. It didn't cost much then. I say have a check in the immobilizer.
08.05.2020 16:16 # 9
muntehaozen
I wrote down all the things you gave, maybe I will not think of your master.
08.05.2020 16:16 # 10
Maybe it's a very simple thing .. did you remember what happened to me? & nbsp; "Grin" a fuse did not apply to the gas pump. ; "Laugh"
08.05.2020 16:16 # 11
muntehaozen
Friends, we started the car in the first starter as soon as the problem crankshaft sensor (used to measure the engine speed) did not change.
08.05.2020 16:16 # 12
I am very glad that the problem is solved, how did he determine the solution?
08.05.2020 16:16 # 13
muntehaozen
There is a brand peugeot special service in Ankara, when I was on the road, I searched with his computer. > 2011-10-25 20:49:42
08.05.2020 16:16 # 14
BurakGONULAL
[QUOTE = muntehaozen] And I am concerned about the possibility of being a catalyst, as you know, is an expensive piece? After the flood of Istanbul, the vehicles that perte with this kind of water damage were very hand-changed, and all of them have this problem. 307XT 2011-10-25 23:31:25
08.05.2020 16:16 # 15
muntehaozen
[QUOTE = 307XT] [QUOTE = muntehaozen] And I am concerned about the possibility of being a catalyst, an expensive piece as you know? may be one of the models
After Istanbul flood, this type of vehicles that perte with water damage was very hand-changed, and all of them have this problem, as a common pert record table. div> [/ QUOTE]
I bought it in April this year. I don't know if it was there in Istanbul flood: S ...
license plate: 06AE4387 & nbsp; can you check it and give me information?
