The tire problem emergency assistance at 206 xt ....
08.05.2020 15:15 # 1
yusuf206
Greetings friends 205 205 16 I have just worn, there is a problem of rubbing on the tires ... only two tires on the rear have original springs on the car ... if I change my tire size or if I play with my spring ... I am waiting for your help.
08.05.2020 15:15 # 2
It was normal to wear, you had to wear 195 soles or 45 cheeks.
08.05.2020 15:15 # 3
yusuf206
Could I eliminate this problem if I have 195 50 16?
08.05.2020 15:15 # 4
You should make 195 45 16 ... If I remember wrong, 206 models with original 16 "wheels have 195 45 16 tires.
08.05.2020 15:15 # 5
What was the original size?
08.05.2020 15:15 # 6
d3n1s
I have a quiksilver, the original tire size of the car is 195 55 15, it says so on the sticker on the door. Calculate here 195 50 is the original size that will be the same diameter as 16 tires, so 195 50 15 tires should not rub? but some 206's standard tire size is smaller than the diameter of my car, including GTi's?
08.05.2020 15:15 # 7
yusuf206
175 65 14 must be the original
08.05.2020 15:15 # 8
[QUOTE = d3n1s] I have a quiksilver, the original tire size of the car is 195 55 15, it says on the sticker on the door. Calculate here 195 50 is the original size that will be the same diameter as 16 tires, so 195 50 15 tires should not rub? but some 206's standard tire size is smaller than the diameter of my car, including GTi's? [/ QUOTE]
195 50 16 and 195 55 15 are not the same. 195 50 16 in diameter becomes larger. I guess the hoods of Quiksilver are already larger.
08.05.2020 15:15 # 9
[QUOTE = yusuf206]
Then you should wear 195-45-16. Cuk sits, there is no rubbing.
08.05.2020 15:15 # 10
yes gti's 15 "tire 185 55 15 truck :))
195 50 16 can be worn. According to 195 55 15, 1% is big. If you wear 45 16 45% will be small ...
the cecol 2011-04-09 22:27:22
08.05.2020 15:15 # 11
[QUOTE = yusuf206]
One minute or did I mix the case :))) If this is the original size, you should wear 195 45 16. There will be no other choice. berkay is peeling right ...
08.05.2020 15:15 # 12
yusuf206
195 45 16 experiences
08.05.2020 15:15 # 13
d3n1s
teacher, look at the sticker on the driver's door and learn the original tire size of your vehicle, calculate the diameter of that size, for example 195 55 15 for a tire, this calculation is as follows (195 * 0.55 * 2) + (15 * 25.4). Here, the tire width of 195 tires in millimeters indicates the ratio of 55 sidewalls to the tire tread in percent. When calculating the diameter, it is necessary to take into account the sidewall thickness twice. It is the diameter of the 15 rims in inches, we multiply the inch by 25.4 to convert it to millimeters. Do the same to the tire you want to wear, you need to attach the tire with the smallest possible difference.
08.05.2020 15:15 # 14
se®k@n
If you wear 195/45 / R16, you won't have a problem.
08.05.2020 15:15 # 15
[QUOTE = d3n1s] teacher, look at the sticker on the driver's door and find out the original tire size of your vehicle, calculate the diameter of that size, for example 195 55 15, this calculation is as follows (195 * 0.55 * 2) + (15 * 25.4). Here, the tire width of 195 tires in millimeters indicates the ratio of 55 sidewalls to the tire tread in percent. When calculating the diameter, it is necessary to take into account the sidewall thickness twice. It is the diameter of the 15 rims in inches, we multiply the inch by 25.4 to convert it to millimeters. Do the same to the tire you want to wear, you need to attach the tire with the smallest possible difference. [/ QUOTE]
It doesn't have to be done inside.
just enter the necessary information :)) be on your mind ...
08.05.2020 15:15 # 16
d3n1s
what more do I have but I did not put it as an advertisement :)
08.05.2020 15:15 # 17
[QUOTE = d3n1s] what else do I have but I didn't put it to be advertising :) [/ QUOTE]
so you are wondering about it Gülme
08.05.2020 15:15 # 18
[QUOTE = berkaygr] [QUOTE = yusuf206]
very correct
08.05.2020 15:15 # 19
d3n1s
[QUOTE = cecoli] [QUOTE = d3n1s] what I have more but I didn't put it as an advertisement :) [/ QUOTE]
Master, if you are curious about it, it is huge, it is forbidden to advertise except for sponsors, it is forbidden to advertise it, it is a java application that I know that it will be stopped. )
08.05.2020 15:15 # 20
okay I'll throw you wait :)
Page : / 3
