The tips of the diesel car!
08.05.2020 14:00 # 1
A lot on the car's 1.6-liter diesel engine with in Turkey. So it has tax disadvantage. This situation returns to the consumer as an extra fee. The economy provided while driving is crushed under the price difference when you first buy it.
If you are a consumer who uses the car you bought for a long time or has come a long way, it earns a diesel engine car. It is not economical to use a diesel engine car if you are a consumer who does not exceed 40-50 thousand kilometers per year or if you are going to drive your car for less than 3 years.
New technology diesel engine cars are no different from their gasoline brothers in appearance. Therefore, even if you say 'diesel' while buying fuel, the pumpers perceive it as 'unleaded'. Events like accidentally putting gas in the tank occur frequently. If gasoline is accidentally placed in the tank, the gasoline that is put into operation without starting the engine must be removed from the tank.
When the engine is cold, turn the ignition halfway and wait for the warning lights to go out. When the required systems heat up, the lights will go out and the engine will run at once, even though it is cold.
Allow the engine to warm up when it is cold. Diesel engines heat slower than gasoline. The cold engine on the start becomes jerky, disrupting the comfort.
alıntıdır
08.05.2020 14:00 # 2
sinan-s
thanks for the info
