the tall does not close
08.05.2020 18:37 # 1
efesbright
Friends, weird things came to me today,
While the main beams stop and go on, I do not turn off. I removed the headlight sockets and plugged it in again. My 207 2008 model vehicle. Any of these causes do not light up any warning lights. Is there a problem in the brain? Continuous vehicle cuts headlights bidet
08.05.2020 18:37 # 2
Alicilik
Ahahaha similar incident occurs in 207 of the cousin. I still haven't figured out the 207 headlight parts are a bit too gentle. Because in other forums, I have encountered many problems with headlights. I don't know what happened to you, but sometime there was a blasting headlight of the 207s.
In the cousin 207 (2011 1.4hdi trendy), the left fog is not extinguishing so I disassembled the socket and insulated it so that it does not get water. Possible problem is the relay in BSM but I could not look in detail. I will solve it tomorrow or Tuesday.
08.05.2020 18:37 # 3
efesbright
The headlights are constantly exploding :) 4-5 times the brakes park the rear fog, the ten fog short beam headlamps detonated them 4-5 times in 2 years. I am not changing for ten months now. Rear right fog breaks out :)
08.05.2020 18:37 # 4
206cc57
The French are very unsuccessful in electronic ...
08.05.2020 18:37 # 5
fatihgg
[QUOTE = efesbright] Friends, weird things came today,
While the main beams stop and go on, I do not turn off. I removed the headlight sockets and plugged it in again. My 207 2008 model vehicle. Any of these causes do not light up any warning lights. Is there a problem in the brain? Continuous vehicle cuts headlights bidet [/ QUOTE]
I had a good chance to do it from the signal lever, I had it repaired.
again you check the insurance vss ..
08.05.2020 18:37 # 6
efesbright
friends I write an old subject, maybe it will happen to you,
The solution to the problem is in the fuse box, there are dipped or high beam relays inside the fuse box, the headlight does not go out because the relay is stuck.
You will either open a fuse box for a good master and have it checked, or you will get a new fuse box without any hassle. opening the fuse box is a bit difficult, maybe it won't open. I bought the fuse box, right now there is no problem.
