The taillight lights when 206 patches are released
08.05.2020 20:30 # 1
ziya alp
friends, my car lights up for the last 3 days while the stop lamp and the handbrake light are on, why does it full oil etc.
08.05.2020 20:30 # 2
If the oil level switch is defective, it may turn on the stop light. If the third stop lamp comes on there is a possibility of a strange short circuit.
08.05.2020 20:30 # 3
talip206
Sir, the brake hydraulic level is low, so it does. If it climbs on a hill, 99% brake fluid is reduced.
08.05.2020 20:30 # 4
KILIC
Probably check the water of your water-reduced vehicle as soon as possible.
08.05.2020 20:30 # 5
ziya alp
We added the brake fluid, the problem was solved, thank you guys :)
08.05.2020 20:30 # 6
boruc
Get well soon..
talip206 made a point shot. Congratulations
08.05.2020 20:30 # 7
ALLEX
[QUOTE = loan] Get over ..
talip206 made a point shot. Congratulations [/ QUOTE]
I think it was a point shot. :)
Long ago, I had the ramp up stop warning and lived. Confused
My 206's problem was that the water level was lacking, though.
Lamp It is necessary to check the liquids in the vehicles (oil, engine water, brake fluid, edge blue fluid, dissection fluid etc.) at regular intervals. If the fluid levels of the vehicles are close to the limits, it is frequently encountered to give such error warnings.
08.05.2020 20:30 # 8
madblueblacksea
Brake fluid is not a volatile thing. There are leaks, the pads are exhausted. If the pads are out, the hydraulic you put after the change will be too much
08.05.2020 20:30 # 9
talip206
[QUOTE = ALLEX] [QUOTE = loan] be over ..
They said that donkeys are the best moments of donkeys. I guessed because it happened to me :)
He was missing from my brake center, so he was missing. You have to bend under the car and look inside the wheels, and if there is a leak in the brake centers, the flowing oil can be seen.
By the way, for the first time, I was delighted that my car gave a malfunction signal :) if it did not give a warning, but it did not keep the brakes in place. talip206 2017-08-16 22:52:09
