the tachometer of my vehicle does not work
08.05.2020 17:49 # 1
peugeotttt
friends, I came home with my car two nights ago, everything was working fine. The next day I went with my car again and I saw that my tacho clock was not working. What is the problem. It was working the day before. What happened while I stopped?
08.05.2020 17:49 # 2
samet206
In peugeot 206s, the indicator problem usually comes up, you can do it yourself if the electrician takes care of it or if you have a hand, but if it is not, I would not recommend the panel is 350 TL because it is past.
08.05.2020 17:49 # 3
peugeotttt
why did this problem.
08.05.2020 17:49 # 4
Gokhan Cetin
the indicator did not work completely in me.
08.05.2020 17:49 # 5
Turgay_66
I don't use the tachometer like that.
08.05.2020 17:49 # 6
peugeotttt
Well, when we go to the electrician, let's see why he did it.
08.05.2020 17:49 # 7
moschino
It is from 99% engine.
mine was broken, when I say let me do it, I also destroyed the speedometer and the LCD display on the top.
08.05.2020 17:49 # 8
peugeotttt
the tachometer has improved on its own now it works. love it saved me the expense :))
08.05.2020 17:49 # 9
EmreOz
Again, I had the same problem in my brother to be malfunctioned. I sold it in that way. 206 is a common problem: S
08.05.2020 17:49 # 10
peugeotttt
[QUOTE = EmreÖz] My brother who will be presented again had the same problem in me. I sold it in that way. A common problem in 206: S [/ QUOTE]
Exactly my teacher has failed again: ((It is not working again.
08.05.2020 17:49 # 11
cetintas
206 indicator issues fixed!
Hello friends, I had the same tachometer problem, I used it for a couple of months, but on the one hand, I got the information from the friends who experienced this problem by plugging in the net through the comments and finally decided to insert and repair the indicator. right here in the attached problem, this tab was broken when I removed it, instead I attached a metal wire and recovered the indicator now there is no problem working
Before doing this process, I asked the service masters, they said there is no repair, and they asked for 1500 lira money for the entire indicator. The stepper motor is not sold only. / watch? v = mhdx1q4b-J8
08.05.2020 17:49 # 12
smiley
[QUOTE = cetintas]
Çetin made a quick entry to the forum, the first message was to solve the problem, welcome :)
08.05.2020 17:49 # 13
cetintas
good news, brother construction is a solution to this problem!
08.05.2020 17:49 # 14
ibanez_022
Hello friends, where does Peugeot-Citroen get tachometer movement on the engine side? In my car, the tachometer sometimes does not work, but I am sure the dial is intact, playing a socket or cable from the barrier under the hood does not work.
Vehicle citroen zx 1.8i 8V Peugeot 306 1.8i same engine completely
