The tachometer flickers at 0 .s
08.05.2020 21:09 # 1
AhmetSehzade
When I Start My Car First, the Tachometer flashes at 0, then it comes back to itself It comes to normal at 1000 revolutions. in ahmetsehza 2019-02-06 21:56:35
08.05.2020 21:09 # 2
When he first opened the ignition, he was doing it as if he was gone.
08.05.2020 21:09 # 3
AhmetSehzade
[QUOTE = sonerkyl] is a momentarily pretend to wake up when the ignition is switched on first. [/ QUOTE]
No, brother, always shaking, we clicked, he shots at 0, he gets up after 30 and 40 seconds after running
08.05.2020 21:09 # 4
It is very likely Ahmet on the subject that I gave you the problem link
08.05.2020 21:09 # 5
AhmetSehzade
[QUOTE = sonerkyl] it is most likely ahmet on the engine that i give you the problem link
I guess yes it can be brother
08.05.2020 21:09 # 6
Karacocuk24
I don't think it will be a problem, but if you want, you can remove the glass part of the dashboard and click for a couple more minutes, if you can not get it, if you do not trust yourself, if you do not trust yourself, if you can not trust yourself, they are following the new one in places that do auto electronic work outside.
08.05.2020 21:09 # 7
AhmetSehzade
[QUOTE = Karacocuk24] I do not think it will be a problem, but if you want, if you can remove the glass part of the instrument panel and manage it for a while more, they can follow 100-200 as much as I know if you cannot trust yourself if you do not trust yourself. QUOTE]
Himm wait a bit then I don't trust myself, so I'm afraid I will have it
