The System I Consider For 206
08.05.2020 14:06 # 1
alpayarzu
Friends I want to make a middle way system for summer, but I need your ideas.
Main unit: Pioneer 5150
Front speaker: Infinity Reference 6520
Rear Speaker: Infinity Reference 5020
Subwoofer: Infinity 1250 watts 30 cm
I have no idea about anfi. I have a budget of up to 300tl for anfi. Which brands can you recommend and how many channels should it be?
08.05.2020 14:06 # 2
JBL amplifiers are good, you can see the heat easily.
08.05.2020 14:06 # 3
Onur
yeah they say very nice to jbl s meanwhile he kept doing it jbl
08.05.2020 14:06 # 4
Carmania
It can be JBL 75 * 4 .. if you get less, it can be in Sierra SRA 1004
These two amps have 4 outputs, you can bridge 2 channels and give them to the bass, and the rest will work for the mids.
(I use it myself is fine) I know the Inno series is not good
08.05.2020 14:06 # 5
H-a-d-i
I definitely recommend the JBL 6 channel "755.6" model. 4 normal speaker channels + 2 bass channels. The 755.6 model is ideal in case the bass are increased to 2 in the future.
The 5150 model is also expensive. I would buy a model without a cap. 3150 is almost the same as the feature, the only difference is that it is more elegant
h_307 2009-12-05 18:28:34
08.05.2020 14:06 # 6
alpayarzu
Thanks guys. Then a 4-channel amplifier does my job, right?
08.05.2020 14:06 # 7
H-a-d-i
The front speakers can be connected to 2 channels, the rear speakers to the main unit, and the 2 channels remaining in the amphitheater can be connected to the bass as a bridge.
08.05.2020 14:06 # 8
easily see
08.05.2020 14:06 # 9
alpayarzu
[QUOTE = h_307] front speakers can be connected to 2 channels, the rear speakers to the main unit, and the 2 channels that remain in the amplifier can be bridged to the bass. [/ QUOTE]
If the rear speakers are connected to the main unit, is there no power loss?
08.05.2020 14:06 # 10
H-a-d-i
the unit has 4 speaker outputs. 2 speakers will be connected to the rear speaker and the remaining 2 will be idle. You will connect the amplifier to the RCA outputs of the unit.
absolutely no loss of sound / power.
08.05.2020 14:06 # 11
alpayarzu
I mean the loss of power, that means if we connect the rear speakers to the headunit, not amphitheater, it wouldn't work inefficiently? I know I asked some questions but see the exposure :(
08.05.2020 14:06 # 12
H-a-d-i
you will have to do so. because there are no more outputs to connect to the amphitheater. If you want to connect the rear speaker to the amplifier, you will get a 755.6 model JBL with 6 outlets.
then "4-channel amplifier does my job, right?" The answer to your question is NO.
or if you get 4 channels, you will do as I said. No other choice. good luck already. enjoy it.
08.05.2020 14:06 # 13
alpayarzu
Ok thank you very much
