The system burns Psp
08.05.2020 18:12 # 1
Enis KORKMAZ
Hello friends I have been using psp in the system for a long time, but 3 months ago the motherboard of psp burned.
I gave it to the service, they started to use it again, it passed, 1 month again, the same sizzle and the same problem motherboard ties burned. I decided to have it done again, but this time I will not start using it without taking my precaution.
The service is called the following: They said this is a problem because the voltage is input from the headphone jack (Audio output).
Now I would be glad if you helped to solve this problem.
Amfi 3000w, I think the amp either draws a lot of watts from psp or gives voltage backwards and burns psp itself.
If we put something in the middle of the audio cable going to this amplifier, it would prevent voltage from coming back or balance it if it didn't draw too much?
PS: Amplifier cable goes directly from Psp. There is nothing on tape. Do I need something fixer on the cable between Amphitheater and Psp?
Enis KORKMAZ 2014-01-13 22:45:25
08.05.2020 18:12 # 2
rifatseker
Then, if you put a suitable pre-amplifier in between, there will be no problem.
08.05.2020 18:12 # 3
Enis KORKMAZ
There are condensers, little things are less costly and they talk about how they can work.
08.05.2020 18:12 # 4
this is the amplifier of the direct home cinema system you call an amp?
08.05.2020 18:12 # 5
Enis KORKMAZ
Auto amplifier
08.05.2020 18:12 # 6
Enis KORKMAZ
Have any other ideas?
08.05.2020 18:12 # 7
Enis KORKMAZ
Any other idea?
