The strumming sounds coming from the door were cut off (with photo)
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:20 # 1
gngburak
through the doors & nbsp; jingling sounds, especially on the rough road. I was pissed off
& nbsp;
& nbsp;
I removed the door trims
& nbsp;
door clips
& nbsp;
fixed it with the help of a silicon gun
< / DIV>
& nbsp;
is now noticeably gone.
08.05.2020 17:20 # 2
Serkan
Your hand is my health teacher, I have it in my hands, the sound of the stinking, the weather will get a little warm
08.05.2020 17:20 # 3
gngburak
Well, the tiniest sound out of the car drives me crazy
08.05.2020 17:20 # 4
gngburak
[QUOTE = 307bursa] I have put the installation in my hand, the health has been nice, these problems have come out, the weather will be improved, I will be losing my baggage including the bag for now. = "Big smile" title = "Big smile" /> [/ QUOTE]
just open the music so that I don't hear the sounds
08.05.2020 17:20 # 5
cnrars
Oh, and it would be nice if you told me how to disassemble the door :) There are rattles coming from the right rear and left front door, probably the speaker or something came out, and the glass is shaking when the window is open, so I hit it inside the door when the window is open (or so). When strange noises are coming, and when pine is opening, cracking noises are coming, as if the dust is breaking down, what should we do? How do I remove the doors, where are the screws, can you tell me?
08.05.2020 17:20 # 6
Thomassee
Sir, I want to ask a question about this.
When I open it from my driver's door, the sound is coming.
The sound comes from this piece. .jpg "border =" 0 "/>
I got it in yellow. I see it playing while it is opening. Is it okay if I squeeze this a bit?
Or do I need to lubricate it?
Teşekkrü on.
08.05.2020 17:20 # 7
Alicilik
[QUOTE = cnrars] ah, and it would be nice if you told me how to remove the door :) I see the rattles coming through the right rear and left front door, probably the speaker or something else came out, and the glass is shaking when the window is open, so the window is open (half as much and so on) when I knock inside the door, weird sounds are coming, and when the pine is opening, the crackling noises are coming, as if the dust is breaking down, what should we do? how do I remove the doors where are the screws, can you tell me? Remove the points marked by the friend, the rest is already there.
Glass slides lose oil or dust soil over time, first you need to clean them and then lubricate them with grease. Every time you open and close the glass after lubrication, the glass that comes to the sleds gets oiled and dirty, and you clean it. "LOL"
08.05.2020 17:20 # 8
Barut
friends today I removed the doors and found the source of the sounds, the sound comes from the lock latch, I put the diaper behind it sound stopped & nbsp; "Big
08.05.2020 17:20 # 9
cnrars
[QUOTE = Receiveness] [QUOTE = cnrars] oh and it would be nice if you told me how to remove the door :) I see the rattles coming through the right rear and left front door, probably the speaker is shaking, the glass is shaking while the glass is open, so when I knock inside the door with the window open (half as much), strange noises are coming, and as the pine is opening, the crackling noises are coming, as if the dust is breaking open, what should we do? how do I remove the doors where are the screws, can you tell me? Remove the points marked by the friend, the rest is already there.
One with you we need to have a break with you :) you know a lot about 206, & nbsp;
08.05.2020 17:20 # 10
gngburak
[QUOTE = cnrars] ah, and it would be nice if you told me how to remove the door :) I see the rattles coming through the right rear and left front door, probably the speaker or something else came out, and the glass is shaking when the window is open, so the window is open (half as much and so on) when I knock inside the door, weird sounds are coming, and when the pine is opening, the crackling noises are coming, as if the dust is breaking down, what should we do? How do I remove the doors, where are the screws? Can you tell me? Have it unscrew it with the help of a screwdriver pull it upwards. There are screws, unscrew it, too. There is 1 screw in it, unscrew it, too.
is finally holding the door clips, gently pull the door interior trim with the door. you do.
08.05.2020 17:20 # 11
gngburak
[QUOTE = Thomassee]
When I open it from my driver's door, I hear the sound.
The sound comes from this track. .jpg "border =" 0 "/>
I got it yellow.
Thank you.
I do not handle it because it does not bother you because I have that sound, let me check it for you.
08.05.2020 17:20 # 12
ahmed206
I can't stand or disassemble now & nbsp; "Big
