The steering is still hard ..
08.05.2020 20:49 # 1
sosyolog_56
Good for everyone. I talked about the previous topic that my steering wheel is hydraulic and electricity is off. I solved this by changing the pump. then we changed the sockets in the electrical box. I have a normal steering wheel but I used another 307. and I saw my car's steering wheel harder. sometimes it feels so soft but usually hardens enough to develop the arm muscle. I got to the master today. The steering box's electronic board has been disturbed, then the steering shaft or the ball, like some other shaft, has faded. this time he cleaned it, soldered it and repaired it. While I was in the industry, the steering wheel I had with my finger is now hardening like the Sahin steering wheel. I paid close to 1500 lira, not only on the wheel, but even when I write my solution, damn it.
08.05.2020 20:49 # 2
Boyunique
Hi, my brother, when I first took my pejom, I did not play anywhere, there was now a pipe that goes to the steering pump. intermediate steering was like tractor steering. Check it out and see if there is an electrical leak on it. I hope it gets better
08.05.2020 20:49 # 3
sosyolog_56
teacher, can we reach this pipe from the engine section? Lifting in the fiber.?
08.05.2020 20:49 # 4
Boyunique
The steering pump is already on the top left, there is a steel pipe going to that pump, follow that pipe to the right, there is a sensor as far as the finger pulled its plug. Also, this steering pump does NOT place brake fluid. it has different oil, I think make it a control. I hope they can help you
08.05.2020 20:49 # 5
sosyolog_56
We cleaned the sensor, we changed the end of the plug in the electrician, and also replaced the original socket on the steering pump in the fuse box with the original, cleaned and soldered. the result is still the same. When I first run it for a while, it is soft and beautiful, but then it hardens from time to time and continues to soften again ethically. they put the ATF 2 oil of the PO as the steering oil of the problem. we also cleaned the ends of the electrical box. the result is disappointment. i understood that our tongue is now burned. It's been 4 months. I made close to 4 thousand TL. I said I'll use it until it is old. pejo after that? NEVER .. I hope there will be no such tool again. sosyolog_56 2018-04-04 16:21:11
08.05.2020 20:49 # 6
ggitaristt
Sister is hard steering compared to other obvious vehicles in my 307 ..
Once it broke down, I had it repaired and worked back as before .. I did not put it on the hard mert head.
If they say to me, give me that much money, it will be like cotton.
In addition, I changed the rim tire 17 rim 225 tire .. Now it seems relatively soft.
08.05.2020 20:49 # 7
sosyolog_56
[QUOTE = ggitaristt] My brother 307 is the hard steering wheel compared to other obvious vehicles ..
teacher. pejo 307 liters of oil. Steering pump or steering oil.
sosyolog_56 2018-04-08 17:03:43
08.05.2020 20:49 # 8
ggitaristt
[QUOTE = sosyolog_56]
I remember that I bought 2 liters to be a lie increased slightly.
