THE STARTER IS PRINTING THE VEHICLE DOES NOT WORK EMERGENCY AID !!!
08.05.2020 20:01 # 1
tuna84
Hello friends, I want to talk about the trouble of my car 207 2006 model 1.4 diesel I have a vehicle in 180 thousand, it has been working hard for the last fifteen days, maybe it did not work in the last days, especially when the weather got cold, it did not work in the last days, even if I turn the ignition even if I turn the ignition again we pulled the car to the industry and the starter motor was examined first, the coals were finished, they changed, cleaned, and then it was said that the spark plug could be changed because it was working at night, and the spark plugs changed but the problem was not improved, the traction of the vehicle was accelerated very well, it is good, there is no problem when it runs late. The masters also said that the direct injectors will change and I did not see any signs for them to change, at least not all of them, then the vehicle remained in place for two days. I used the pump in the engine part manually to start it. raç is working alone, something that I have never met, I gave a goose break, intermediate vehicle, the car dropped out of black smoke, the place officially threw it on the ground, I kept repeating it for a long time, I would go back to the industry again, but usually most people call it a short-cut injector, but it could be carbon cleaning or something like that. I think an injector is 500tl in the result and what I pay attention to is that when I take off in the first gear, the accident pressure may be in the engine during full acceleration, it sounds like a fuzzy sound comes from the exhaust, the problems that come to my mind are the exhaust is blocked, the injectors are dirty or the diesel pump does not pump or malfunction. I am waiting for your help. Can anyone meet or what can be the solution? Thanks in advance.
08.05.2020 20:01 # 2
xmen
As if the diesel pump is in trouble, sir. The tool of my last brother-in-law was similar. The problem is the diesel pump.
08.05.2020 20:01 # 3
pepecura
Have the spark plugs checked, if the spark plugs are intact, have the spark plug wires inspected. Does the spring picture blink after the starter?
pepecur to 2016-11-05 10:24:43
08.05.2020 20:01 # 4
pepecura
all he wrote happened to me in multijet font. the spark plugs were intact, there was something like a spark plug actuator. he was getting starter in seconds. Of course, I was a little overwhelmed until I got this experience.
08.05.2020 20:01 # 5
KILIC06
bro, replace the diesel filter, probably the diesel is escaping especially when you park the ramp up, the vehicle will not work, the ramp will run down easily, most likely there is a check valve in the mouth of the filter, as I said, it is malfunctioning.
08.05.2020 20:01 # 6
tuna84
My brother of XMEN diesel pump is very surprising to everyone's mind, but one of the masters does not think of it, I am surprised at him, as you said, I will search and look for around 1250 TL.
My brother PEPECURA will also look at the spark plug roles, it sounds like it is probably a small and low cost master, as you said, the masters choose the expensive way first, but that spring light never burned on me bro
KILIÇ06 brothers, I changed the filter after the complaints increased, maybe the new filter is clogged or there may be a different malfunction
THANKS FOR YOUR FRIENDS ALWAYS THAT YOU REALLY GIVE ME VERY GOOD IDEAS ON THIS TOPIC. ShockedClapClap
08.05.2020 20:01 # 7
KILIC06
my brother 3 weeks ago, my car is running back the diesel, the car was not working, I changed the filter, I bought delphi brand, the fault continued, I said you will install the original :)) after that, I bought the original filter of the piano, 80 lira definitely said it will not fail. Tak said :)) I said enough, they said, "Then change the handpick with that hand, then they said it is 225 lira (check it, if you don't have a kece or do not be fooled) they said injector, we just insert it, if it doesn't come out, we said we will change 200 lira, I changed it, I changed it, I changed it, I changed it. As well as you can understand, the shelf life of these filters is sold and we spend money on other events because we just changed them ... When it comes to the pump, the diesel pump does not break down easily.
08.05.2020 20:01 # 8
Taner
I have the same problem with me 307 2006 1.6 hd pistons have reached 2000tl cost diolar
08.05.2020 20:01 # 9
tuna84
ClapClapClapClapClapClap Thanks guys, I want to ask you where the spark plug heating relay is located. Today, I will order one heating filter. I will try both of them. I tried to disassemble it and try to operate it. The reaction of the vehicle was the same with the reaction before dismantling. It seems to me that this event seems to be solved with this simple relay event or with the diesel filter.
08.05.2020 20:01 # 10
tuna84
Friends problem is solved now, the problem of working of the vehicle has disappeared, after the maintenance, it made us find the source of the problem more easily. If the tool is not being pressed just because of this simple reason, the masters would call the injector as normal, maybe they said that we solved this problem and changed it and they would take 800tl money and deliver the car, so it is very good to be careful. Do not hurry, we become victims of masters when we think so. Thanks for your comments.
08.05.2020 20:01 # 11
KILIC06
I said brother, filters, trouble Smile
08.05.2020 20:01 # 12
NAZIM69
It is necessary to find the good and honor of the masters.
my master is number one in this regard, even for the part that man needs to change, he opposes me to open the charge, saying that it carries you for a long time, not the only one but everyone treats the same. God, the guys even provided international technical support to peugeot and citroen.
I recommend, www.akdanotomotiv.com you can find information from this web mail.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
