The starter is pressing halfway, working with knock or pull
08.05.2020 21:05 # 1
Jed69
friends, I've had a 106 in 270 thousand, I've been having trouble with the starter for a couple of days, this day broke out, I am starting to press a sound similar to the sound of a two-second bi-skid. It cuts everything, waiting for your answers and suggestions Jed69 2018-12-07 20:45:25
08.05.2020 21:05 # 2
Jed69
Now I tried again starter complete gone click
08.05.2020 21:05 # 3
pusutr
Have the starter motor checked. Is the battery intact? If it is intact, remove the battery, click and try.
08.05.2020 21:05 # 4
Jed69
The teacher I took to the master started to work with hitting the crank reader sensor, but it did not make sense to me.
08.05.2020 21:05 # 5
ColoneL
[QUOTE = Jed69] I took it to the master, it started working with hitting the crank reader sensor, but it didn't make any sense to me.
Brother, I had something very similar to what he said by saying I have 206 vehicles. I heard this one more time and the car did not have a problem. I wonder where this sensor is. What is it? If I try it :)
08.05.2020 21:05 # 6
talip206
[QUOTE = ColoneL] [QUOTE = Jed69] The teacher that I took to the master started working with hitting the crank reader sensor, but it didn't make sense to me, I will show it to a master again at the beginning of the week [/ QUOTE]
In such a situation, if the battery is intact, there is a problem in either the starter motor or the crank sensor. The crank sensor is sensitive and does not hit much. Generally, if the car is not automatic, it is moved a little while in gear so that the crank position changes and the car starts when the starter is pressed.
The crank sensor is located in front of the car, behind the radiator (on the engine side) and slightly below. It is located to the right of the oil filter for you. The shape that is usually gray is slightly different and you can see the cable.
Gasoline 206 1.4 sample crank sensor.
talip206 2018-12-09 18:29:29
08.05.2020 21:05 # 7
ismailkaya
the crank sensor does not start the vehicle, everything works as soon as the starter
08.05.2020 21:05 # 8
ismailkaya
starter can scrape on the engine. or may have been maintained
08.05.2020 21:05 # 9
KvncKR
Did the indicator lights light up a little bit at the beginning of the problem? The problem may be caused by the alternator (charger). It is very normal for the alternator to expire in a 20-year car.
