THE STARTER IS PRESSING AND THE VEHICLE DOES NOT WORK.
08.05.2020 19:35 # 1
yaman14
Hello friends
I am writing from the village containing yaman istanbul
I have a very interesting 2004 model 307 xt vehicle.
Although the engine of the vehicle does not start when it is cold,
I hit the car and run it. I go to the auto electrician.
We changed the spark plugs of the car, there is no problem in the starter motor, there is gas in the car.
We couldn't figure out if there was any possibility of being immobilizer.
If the keymaker is starting, he said it has nothing to do. NO KEY REPLACEMENT.
there is a situation
I lock the car with the key and pity can be related to the alarm system
CAN I TAKE YOUR IDEAS
08.05.2020 19:35 # 2
welcome yaman bey first of all, you can get better help if you answer yourself from the member promotion section. good forums.
08.05.2020 19:35 # 3
yaman14
Thank you for your information.
08.05.2020 19:35 # 4
I guess it's not lpg in the vehicle. Did you also have the gas pump checked? I think there is a retrofit alarm system in the vehicle.
08.05.2020 19:35 # 5
mhmtclb
When there is immo shortage, the car will start until the battery runs out but it will not start. When I changed the remote, I forgot the immo outside and I tried to get there.
08.05.2020 19:35 # 6
talip206
A similar problem happened with me as if the problem is gone today, but I will have it. My fear is that the problem is not found and a lot of parts are wasted. No lpg, I think, firstly measure the pressure of the gas pump. Clean throat butterfly, check gas filter, air filter. These are cheap then have the sensors checked. Like map, heat, oxygen sensors. Unfortunately, there is no definite result of a problem. So it's good to go from cheap to expensive
08.05.2020 19:35 # 7
yaman14
My vehicle has the original central locking system, but it does not open and close the doors from the buttons on the key.
We did not find any problem in the gasoline petrol pumps of the vehicle.
I found an information that the emission sensor is on the air filter, if it is dirty or damaged, it will not work. I will try..
yaman14 2016-01-07 14:24:01
08.05.2020 19:35 # 8
yaman14
Will I work when I hit him from immo?
08.05.2020 19:35 # 9
talip206
In addition, the vehicle starts the car, but does not work on the immo problem, which the keymaker said wrong.
08.05.2020 19:35 # 10
The pc connected tool may have given no error code.
08.05.2020 19:35 # 11
yaman14
They have tied logs.
I stopped and entered the house the next day the vehicle did not work.
08.05.2020 19:35 # 12
KILIC
[QUOTE = yaman14] my car has the original central locking system but it doesn't open or close the doors from the buttons on the key.
I guess there is no sensor in your vehicle (air flow meter or flow meter) in diesel, pugs are not usually in gasoline. Have the temperature sensor checked.
08.05.2020 19:35 # 13
talip206
There is something like a sensor on my car gasoline air filter pipe near the throat butterfly. Do you know what sensor soner he is
08.05.2020 19:35 # 14
The sensor you say is before my throat butterfly, and then there is no sensor in our 1.4 8v before the throat butterfly. There is maf sensor after throat butterfly. It would be better if it was a photo.
08.05.2020 19:35 # 15
talip206
http://www.google.com.tr/search?q=peugeot+206+otomatik+motor&client=ms-android-samsung&hl=tr&v=133247963&tbm=isch&ei=bniovpupcooıps6esygf&start=20&sa=n#mhpiv=9
Sir, I can't upload a photo, but the place marked A in the link I provided
08.05.2020 19:35 # 16
hmm o the part you show is oil steam pipe.
08.05.2020 19:35 # 17
yaman14
yesterday evening i tried to hurt and close the doors, it didn't work again
The switch worked when it cleaned with oxidized thinner inside the switch, but the situation is still the same
08.05.2020 19:35 # 18
Hodja, I say, book a spare key and try it as a result, you will not have any harm.
08.05.2020 19:35 # 19
yaman14
I will give my gallery upside down to the gallery tomorrow.
08.05.2020 19:35 # 20
KILIC
My teacher is very likely to be from the key. In my opinion, as the soner says brain, if I am not mistaken, 70 TL to try and make a spare key. go show it to a keymaker those moments may not already be able to read the immobilizer because it is oxidized
Page : / 2
