THE STARTER IS BUT NOT WORKING
08.05.2020 19:27 # 1
castiel87
HELLO FRIENDS ;
I NEED YOUR IDEAS ON THIS TOPIC. 3 days ago, I bought 20 TL gasoline 50 TL gas. YESTERDAY THERE IS GAS ON THE ROAD, THE CAR HAS GASSED TO GASOLINE. WHEN I WANT TO OPERATE TO GO TO WORK IN THE MORNING, THE ENGINE STARTED TO KICK, I STILL GASOLINE OVER. I WANT GASOLINE ALDM COME I LOADED THE SAME PROBLEM CONTINUES THE STARTER ARE I PRESS 2 SECONDS TIL TRUCTOR SOUND LIKES A RETURN RETURN SOUND BUT NOT WORKING. WHAT HAPPENED TO YOU? ??? ConfusedOuch
08.05.2020 19:27 # 2
talip206
Take the car to lpg and start it. If it works, your gas pump is burned out. If your gas level is low, the chance of your gas pump getting burnt increases. Therefore, do not fall below a quarter of a warehouse.
08.05.2020 19:27 # 3
castiel87
I tried to buy gas by holding my finger pressed. Actually, it went flat after a while. HOW CAN I UNDERSTAND IT IF THE PUMP IS BURNED. OR HAVE YOU HAVE A TENDER UNDERSTANDING THIS WORK.
08.05.2020 19:27 # 4
First of all, my teacher will be under the back seat. If there is no sound when you start the vehicle, it is broken, any master moments will take you to your master who has your maintenance. I also recommend you to change the gas filter. Get well soon.
08.05.2020 19:27 # 5
talip206
My teacher works on LPG when you hold it down and start it. Yours also worked on LPG. 99% burnt gas pump then. Lift the seat of the back seat, it has black plastic underneath, and it has a petrol float and pump when you remove it. If someone opens the contact, you hear the sound and you hear the sound.
08.05.2020 19:27 # 6
sezar206
Get well, my brother, the pump is burned out. If you kept the gasoline in the tank mostly low, it warmed up and burned. You said you are working regularly on lpg. The master will open and understand.
08.05.2020 19:27 # 7
sezar206
The price should be between 250 and 300.
08.05.2020 19:27 # 8
talip206
Complete float pump together from 250 to 300. When my leak (bottom of the outlet plastic hose) had to be completely changed. But the master said that if the engine was only reflected, we would buy 90 TL.
