The Starter Failure Problem IS NOT resolved
08.05.2020 18:42 # 1
MertMurat
Hello friends
The friend, who was interested in coincidence during the examination, also left the forum and had an automatic 307, which is the same as mine.
He gave a lot of advice, and look, it's very important, you will stay in a place where we do not have it done right away.
I stayed in a place where we were not. When I was looking for a parking lot in Sultanahmet, I found a place in one of the side streets, I realized that I parked, then I realized that the narrow street and I need to get a little lift, I started, I started, I said, whatever the click sounds, the starter does not start, the battery is solid, I said, I will take care of the iftar.
1 hour later, I came back, tried the car in one starter the next day, no problem next time, no problem, but I went and told an electrician, let's see the man, let's see coal or something else said
Coals dismantled starter motor intact
He pulled out the collector so that 2 wires were broken, he said that the coals will not work when they come here, so I said, the master collected it back, put it on the battery, brought the broken place to the coal, the engine does not rotate, and the engine worked less.
We said we need to change it, where we find it, before I look at the net price, it says 40 TL.
the master team collected how much money we will give workmanship, I said 70 TL
anyway we got into trouble 50
Long story short, 100 TL entered where we stopped
He said that I would buy this much workmanship even if it was made of coal.
He said it was a very troubled piece to disassemble.
mertmurat 2014-07-20 15:05:41
08.05.2020 18:42 # 2
Serkan
Get well, there is no chance to hit the starter and battery very important equipment in the automatic car, it is also necessary to have a battery booster cable in the vehicle.
08.05.2020 18:42 # 3
ahmed206
A nice bite kit is bought for 50 lira haa :)
08.05.2020 18:42 # 4
emrah_388
The same thing happened to me, both in 206 and 307, the starter was on his head, and if we look at it, it was a problem after I got out of maintenance in my two cars.
08.05.2020 18:42 # 5
okaNStarss
Get well, buddy. sometimes there are umbrellas where we stopped :) okanstarss 2014-07-16 09:47:49
08.05.2020 18:42 # 6
MertMurat
When the engine gets warm, the starter no longer presses
I will take it to the mechanic as soon as possible and share the result, but do you have any friends with suggestions?
I think it might be from relay
08.05.2020 18:42 # 7
ahmed206
Current 1:
The following 2:
Also 3:
I copy the last message in link 3 here.
" It is a long time but now I am writing it for the friends who have come to the fore. I am lpglibise the vehicle LPG regulator. The regulator does not fade and fills the manifold gas and the engine is strangling in the operation. LPG regulator brain change results. "
I do not know which one offered different solutions. Again get well soon.
08.05.2020 18:42 # 8
MertMurat
Yes, the problem is that we got it in the bendix gear because I had an extra room, and we did it without any cost.
On the other hand, the collector would also fail, and it changed in the meantime.
Problem solved
08.05.2020 18:42 # 9
suppor
If your friends shut off when the engine was hot and pressed the starter, if you clicked and stay left, it is automatic and if you change your commands, I want 75 to work correctly.
