The starter does not press, click sound does not work
08.05.2020 20:42 # 1
Ferhatxipek
one Ferhatxipek 2017-12-25 22:59:58
08.05.2020 20:42 # 2
Orcun.Dmr
There are 2 options; Either the battery is exhausted or the starter coals are exhausted.
08.05.2020 20:42 # 3
Ferhatxipek
I changed the battery and made the anthem and it was the same again
08.05.2020 20:42 # 4
Orcun.Dmr
[QUOTE = Ferhatxipek] I changed the battery and made the anthem again the same thing happened [/ QUOTE]
When did you get the starter and checked if all the parts in the starter were replaced with their originals (coil, coal, automatic?) And were you getting a chassis?
08.05.2020 20:42 # 5
Ferhatxipek
The starter was made for 1 week, I did it all but the starter couldn't charge itself or could it be a leak in the car
08.05.2020 20:42 # 6
OguzhanKucuk61
The same came to print 2-3 months ago. It was resolved by automatic and coal replacement.
08.05.2020 20:42 # 7
Ferhatxipek
They call mine electrical, but I'm better off with an anthem
08.05.2020 20:42 # 8
ggitaristt
Brother I think connect to a computer first ..
It happened to my friend on the way, what you said costed 5000 timing.
The same, the starter was clicking, not turning.
No problem with crank sensor or something ..
It's probably a simple thing, but I'm still a little scared of you ..
08.05.2020 20:42 # 9
ysf_syfttn
I had the same problem yesterday, I made the starter engine, but the car worked, but this morning, I started the boat 3-4 times, it was as if it was not getting idle.
08.05.2020 20:42 # 10
Ferhatxipek
I gave it to the electrician, the car charger was broken
08.05.2020 20:42 # 11
Black37
I think the same problem happened when the vehicle stopped, I turn the ignition, no sound, I went to the master, the starter's coal was finished, the workmanship took 120 TL of coal, 2008 sedan gasoline at 98000 km
08.05.2020 20:42 # 12
ysf_syfttn
Grank Vagabond the plug was about to come out instead of the master, the problem is solved kırpmak
08.05.2020 20:42 # 13
luridline
Super, there was no different problem, it happened to me, I had a lot of headaches, the coals changed, the problem was solved.
Get well again
