THE STARTER DOES NOT PRESS
08.05.2020 21:00 # 1
butterfly
First of all, hello peoguet 407 1.6 I have a car, I pressed the starter in the morning, the car did not work yesterday, there was no problem in the car yesterday, I put the key in the ignition in the morning, there was no margin sound, I did not reinforce the battery. butterfly 2018-09-10 12:29:53
08.05.2020 21:00 # 2
butterfly
No sound from the start since the beginning
08.05.2020 21:00 # 3
talip206
Check the main fuses one by one. Assuming you are doing the reinforcement job correctly, there is insurance.
08.05.2020 21:00 # 4
butterfly
I tied the reinforcing cables plus or old to the minus and I started the starter again.
08.05.2020 21:00 # 5
baybaba
it happens when you don't read the immobilizer code in the key , sometimes it happens in my vehicle,
this morning I turned the ignition 2 times did not work, turned the key upside down and put it back in again,
08.05.2020 21:00 # 6
talip206
[QUOTE = baybaba] happens when you don't read the immobilizer code on the key , sometimes it happens in my vehicle,
I know that when it is from the immobilizer, it starts but I do not send ecu fuel. Your friend never started.
08.05.2020 21:00 # 7
ismailkaya
Start with the simplest, if all the electrical functions of the vehicle are working and the starter does not even click on the pressure, there may be socket contact in one of the sensors.
08.05.2020 21:00 # 8
Orcun.Dmr
Mars dynamo may be from command.
08.05.2020 21:00 # 9
butterfly
When the immobileyzer does not read, does it crank? Does it cuddle? Or is there no tick?
I don't have any tick
08.05.2020 21:00 # 10
butterfly
Where is the speed sensor socket? Can you describe it?
08.05.2020 21:00 # 11
butterfly
Can I disassemble the starter to any electric crank and change the coal forward?
08.05.2020 21:00 # 12
Ufuk_64
Find a diesel minibus from one place and make a reinforcement with it. It works 90%. If the battery amperage of your vehicle is the same, if it is not new, it will not work for 2 years. If you cannot find it, try the following (transmitter battery amp should not be less than yours) connect the cables and let the engine run the engine, keep your contact off, so put the key on it, wait 15 minutes then try if you don't click again, remove the battery plus cable of your vehicle minus, do not touch. So, if your battery is disconnected from the vehicle, connect the positive cable from the transmitter to the plus of your vehicle, here it is important to note that if a person keeps the cable intact, it does not touch any part of the vehicle, it will make a chassis. can disrupt the charging dynamo). But the most guaranteed is the minibus.
08.05.2020 21:00 # 13
butterfly
There is a problem with my battery, there is no problem with the battery
08.05.2020 21:00 # 14
Ufuk_64
Last year, in our building of 23 apartments, every floor had 230 volts of electricity on the wall of each room, but it couldn't knock anyone down the floor. ) ..
08.05.2020 21:00 # 15
butterfly
Tomorrow I will take the vehicle to the electrician with the tractor and have the coals to be removed.
I am not thinking about shooting and running, of course I will share with you what the problem is.
08.05.2020 21:00 # 16
butterfly
Will the malfunction lamp turn on when I remove the starter and appreciate it again?
08.05.2020 21:00 # 17
ismailkaya
I don't know where you are in your 407 diesel vehicle but you look for this sensor next to the crank gear
What is Engine / Crank Speed Sensor Malfunction?
If the engine-crank speed sensor fails, the engine will not start. In some models, it can operate in fault mode at constant dervishes around 2000 rpm. When the sensor malfunctions, the connection cables and connection socket must be checked, the sensor may have malfunctioned by cable breaks or short circuits, or by loosening the socket or oil-dirt coating of the ends in the socket.
What are the crankshaft position sensor malfunction symptoms? How to Understand Failure?
* Engine does not start despite starting
* Engine runs hard
* The vehicle stops when driving on the road.
08.05.2020 21:00 # 18
butterfly
Yes, the problem started when the starter changed from the coals.
I thank you all for your help
08.05.2020 21:00 # 19
Crayzmetin
Hodja, how much did it cost to change coals? How long did it take to be a difficult process?
08.05.2020 21:00 # 20
whisky
they bought 50 lira last year for the coal exchange.
