The speed is slow, it gets better when it gets hot.
08.05.2020 20:35 # 1
selman87
Hello,
I own 2009 model 207 1.4 diesel manual vehicle. For about 2 weeks in my vehicle, the gears have been difficult. After traveling for about 5 minutes, there is no problem, it goes smooth. When it is difficult, there is no gear force or other sound, only the gear shifts are heavy. I mean slowly, when you push something, when it gets over the bar, it just sits down, mine isn't. It passes slowly at constant force. As I said, there is no sound and noise. We changed the gearbox oil, put 75w80 oil. There has been some improvement but not as before. I ask for help from friends who have experience with the problem. My car is 140000 km. Could there be anything related to clutch or press brake? There are no original printing pads yet. Or should I urgently have the gearbox checked for this problem? Is there a master in Izmir that you can recommend for transmission. Thanks.
08.05.2020 20:35 # 2
onlycihan
How hard the clutch clutch is, can make the pressure pad a possibility, such troubles. 75/90 oil is actually recommended. I changed the gearbox, but I couldn't catch the first soft version of the gears. Or I was paranoid, it seems to me:) my car is diesel 206 120000 km by the way
08.05.2020 20:35 # 3
outlaw
In the first start of transmission oil, the transition is difficult because the engine is cold, but as the engine gets hot, the oil thinks in the oil and there is no problem in the passages.
For the gearbox, you can trust the master, but if you want advice, I will help you ...
18.12.2020 18:07 # 4
skystar316
Is the problem solved, teacher? I am having the same problem. Should we put 75 80 or 75 90 oil? I guess it changed once, I am not sure. We had a bad master experience. The axle was displaced, the transmission oil was drained in the shock absorber replacement. He said he changed the oil. But then the problems started like yours. Best regards ... 2009 model peugeot 207 1.4 hdi
