The spare key does not start the tool
08.05.2020 20:00 # 1
Sercan Mungan
Good day, valuable forum members, is it a coding situation when my car's original remote key, which is not a starter, opens the car doors but does not start?
08.05.2020 20:00 # 2
talip206
Yes, it is necessary to code the key to the brain of the vehicle. Somehow deleted or the chip inside the key is damaged. Normally he had to recognize it directly.
08.05.2020 20:00 # 3
Sercan Mungan
No damage status key zero already stops with the code card.
08.05.2020 20:00 # 4
talip206
service can be a little salty. It will be cheaper if you go to a place that makes auto switches. I have no idea about pp2000 but it's probably done with it.
08.05.2020 20:00 # 5
Sercan Mungan
Engine immobilizer gives fault error trip computer opens contact but does not start the vehicle.
08.05.2020 20:00 # 6
Sercan vehicle key should be introduced to the vehicle like untumuş. It can be made with pp2000. if not, the immo chip inside is broken. you will have to go to the keymaker
08.05.2020 20:00 # 7
Sercan Mungan
I do not think there is a keymaker who can do it in Kütahya, thank you :) There is no need to go to the authorized service.
08.05.2020 20:00 # 8
Peugeot35
I tried my backup key for the subject you mentioned
Likewise, it opens the door and the ignition and does not start the car. Since the key is new, I think that the coding has not been coded and this code will be solved by loading the code on the key card to the chip on the key.
08.05.2020 20:00 # 9
GokhaN
If you are not the first owner of the vehicle, open the key and look at it.
08.05.2020 20:00 # 10
Peugeot35
I will go to the keymaker and activate the key transactions with you again.
08.05.2020 20:00 # 11
Gokcesel
The spare key of my vehicle opens doors and does not start. I guess it is necessary to code the code on the card. Without a chip, the starter does not start.
08.05.2020 20:00 # 12
Peugeot35
Yes friends For the information of friends who have spare keys and do not open the doors and start the car;
Today I went to the keymaker, gave my spare key and the identity card of the car, first inserted the key in one device and processed it, and then inserted another device into the brain of the car and introduced the key, then the spare key became active.
The transaction fee took 20 TL.
There is a small black chip inside the spare key, so I guess it loaded all the processes into it.
08.05.2020 20:00 # 13
ggitaristt
[QUOTE = Peugeot35]
A little fix: you can't load anything into that chip. The chip gives a certain frequency to a certain frequency. First he finds that frequency unlocking. Then he introduces to the car OuchBig smile
For example, I do not have a spare key. I just get the original key when I go to get it done. I will copy the same. There will be no need to introduce the backup to the car.
Or a key will be taken from the junkyard, the tip will be copied and introduced to the car.
08.05.2020 20:00 # 14
Peugeot35
I don't think there is a frequency event, I guess, the jeep of the spare key is coded and it is written on the card in that woman, and this code is inserted into the vehicle's brain.
The event you said was implemented when a spare key was made to my previous car.
