The sound will drive me crazy ... :))))
08.05.2020 18:02 # 1
sametbeder
Hello friends ....
2004 I have a Model 307 XR vehicle ... I have encountered two problems in the past week ... First, there is an interesting and annoying sound coming from the engine section in the car ... A voice that is constantly "increasing" as it presses the gas. .. It continues to increase and sometimes decreases from time to time ... Secondly, it shakes excessively when the vehicle is stopped or waiting for the lights ... It trembles where it is ... It is as if the idle will stop at low ... But it is not always at certain intervals. doing ... what do you think could be the reason ????
08.05.2020 18:02 # 2
SoSRiQuO
It seems to me that there may be a problem with Ignition Is there LPG in the vehicle?
08.05.2020 18:02 # 3
kuscu38
Do you have LPG and when did you change the triger?
08.05.2020 18:02 # 4
What about the oil level? When was the last maintenance done?
08.05.2020 18:02 # 5
Aziz
[QUOTE = koliva] What about the oil level? When was the last maintenance done?
+1
08.05.2020 18:02 # 6
berk2309
How did the noise increase as it presses the gas? When I say: D, there was a sound like a metal knock, there was a sound, the tensioner bearing of the truck was overstretched and we would help you if you could pull the bearing off.
08.05.2020 18:02 # 7
sametbeder
No vehicle diesel ... No LPG ... I am very sensitive about their maintenance ... When it comes to sound, yeah, just like it, it sounds like a cable, or just like that ... Yellow light fountain next to the arch light today varya like :))) he burned ... I'm overwhelmed ...
08.05.2020 18:02 # 8
atesoyuer
I think it is coming from the timing, I think I have the same problem and I showed that the timing set will be changed, but I can not pay for it now
08.05.2020 18:02 # 9
volkanC2
Maybe something might have been relaxed, it sounds like it vibrates as it presses the gas :) Think well, think well :) I think it was the throat butterfly in the gasoline 106 when I was waiting at idle. .
08.05.2020 18:02 # 10
ozyvet
Like lambda sensor malfunction. The vehicle seems unable to adjust the fuel oxygen ratio. I think the error code should be checked
