The sound that comes in when 307 bumps
08.05.2020 18:33 # 1
cavit cevo
Is there anyone who has the idea that when it comes to bumps, it sounds like a gar in front?
vehicle 2003 307 1.6 petrol manual gearbox
08.05.2020 18:33 # 2
emre_akdag
Shock absorber blocks may be worn. Is the definition of sound exactly 'gar gar'?
08.05.2020 18:33 # 3
cavit cevo
Yeah, it was like a gar, like an engine coming in, like broken gear sounds
08.05.2020 18:33 # 4
Burak
The front tool layout was a classic and empty answer, but anyway :)
08.05.2020 18:33 # 5
cavit cevo
the front team has just been made, there is no space left, there is a left axle space, we will change it.
08.05.2020 18:33 # 6
cavit cevo
What are your pejo masters comments?
08.05.2020 18:33 # 7
qqyyxx
Commenting without hearing the sound can lead you to unnecessary expenses.
08.05.2020 18:33 # 8
cavit cevo
we were told that it came from the gearbox as a result we will make the gearbox 1000 rubles Disapprove
08.05.2020 18:33 # 9
TaZ
My brother, I always read your painful issues, I thought that the price of a car has almost cost you, I thought I couldn't find the sound coming from the bumps, what I think might be related to you, I couldn't find it, please illuminate someone who would find me the sound that came from the night when I passed it, let me be enlightened. No brother, I do not know this rebellion or the man is right, I did not come across.
08.05.2020 18:33 # 10
cavit cevo
bro, I couldn't find any answer on this site.
as you said i spent a lot of money Cry
08.05.2020 18:33 # 11
kuscu38
When my teacher passes through the mound, it makes a direct connotation, a piece of gear is loaded, the room gets tired when it passes through the bump, so if it sounds heavy, it makes no sound, the room is only in the flow and axle head gear. In the 1st gear, take off as if putting a solid paw. Press the throttle to the end and take your foot off the clutch and take off, if it sounds sound like a lacquer lacquer, the axle should be in complete maintenance. or heads, felts, gears can be looked at in pieces. But there may be trouble.
08.05.2020 18:33 # 12
serkomser
[QUOTE = kuscu38] Press the throttle all the way out and pull your foot off the clutch [/ QUOTE]
The method is super LOLLOLLOL
08.05.2020 18:33 # 13
hakan574
if the car is rolled to the ground, it can also come from tires, so the tires may rub against the bodywork
08.05.2020 18:33 # 14
cavit cevo
I will do what you call normal springs in the vehicle. Left flow is changing.
