the sound system i was thinking of doing
08.05.2020 16:51 # 1
sansasyon61
http://www.sahibinden.com/ilan/alisveris-elektronik-oto-arac-sony-xs-gtx121-subwoofer-tum-urlerler-resmi-garantılı- 67322589 / detail & nbsp; & Nbsp; & nbsp; front doors & nbsp; http://www.hepsiburada.com/liste/sony-xsf-1737se-17-cm-3-yollu-hoparlor/productDetails.aspx?productId=otsonyxsf1737se& categoryID = 26090 & nbsp; & nbsp; backdoors & nbsp; http://www.hepsiburada.com/liste/sony-xsf-1337se-13-cm-3-yollu-hoparlor/productDetails.aspx?productId=otsonyxsf1337se& categoryID = 26090 & nbsp; Which would be appropriate, which should I prefer? Before I get too expensive, the 307 is the loud speaker in front of the glass. What should I replace them with now? & nbsp;
08.05.2020 16:51 # 2
sansasyon61
by the way & nbsp; I do not understand this sound system at all :))
08.05.2020 16:51 # 3
CEM1984
Buy a 2000w an amp, Jameson is cheap, I have been using it for 3 years, then I have 1000 jbl or pieoneer, then 400 is 1 double and front 2 doors, I think 180 flan oval 16-17 plug doors, the ones that do not need a little treble, take it out, get it very cheap. girth 100-doors -130-bas170-500lira bidet tape-250 = 750lira over & nbsp;
08.05.2020 16:51 # 4
sansasyon61
nice information ustad sagolaısn I start to take note of them I will make the most reasonable and logical :)
08.05.2020 16:51 # 5
CEM1984
Just remember to add as much speakers as your anfin ...
08.05.2020 16:51 # 6
sansasyon61
For example, if my teacher bought ten back doors or bass set, the subwonder is a maximum of 1000. What power is needed for this? I am not a professional sound system.
08.05.2020 16:51 # 7
CEM1984
1400w is enough - bass is 1000w if you put 200 doors. But if you want to plug it in the future, the speaker ends, buy everything powerful amplifier, little money, 2000w & nbsp;
08.05.2020 16:51 # 8
sansasyon61
Well, I will listen to your master's skill :))
08.05.2020 16:51 # 9
CEM1984
Thank you, good night ...
08.05.2020 16:51 # 10
Alicilik
The acoustics of your car are very good.
There are 20-30tl difference between 13 pick up frames and 16 use for the back, but the difference is quite high.
German requirements;
4 channel stereo amp & nbsp; should give at least 4 * 60w rms at 4ohm.
1 channel mono amp should give at least 1 * 300w rms at 4ohm.
These amplifiers;
According to the money status
Infinity ref6530
kicker ds650 .2
jbl gto6508c (buying 608c)
you can also turn to brands like mtx - soundstream - soundmagus - magnat-alpine.
16-16.5-17cm doesn't matter much.
Besides, I can recommend pioneer-jbl-alpine-kicker-infinity-magnat-focal as bass.
If you have the opportunity to get advice other than listening, try to listen to your voice. It is more important to get the Mid team by listening to the bass. Not everyone's ear taste will be the same.
As anfi, turn to brands like zetec-jbl-soundmagus-philppo-alpine-pioneer.
Apart from these, your main unit-RCA cables and most importantly, your power cable and fuse are healthy. and they must be strong in them.
08.05.2020 16:51 # 11
EmSul
It would be best if you specify a budget before making a recommendation. How much money can you allocate for the system? Otherwise, 500 lira is installed system is 5000 lira ..
The bass in your links are expensive, better products are bought for that money, there is more price. > It is important brand-models that do not only follow the recommendations with values such as 300watt 1000watt 2000watt.
08.05.2020 16:51 # 12
sansasyon61
ScHerZo master is going to look at the precious information according to him ... shumubofnsbi" emrah master butcem ole not big 1000 tl mercury tape mortar
