The sound of yesterday coming in 307 cold anthems |
| 08.05.2020 19:37 | # 1 |
| 08.05.2020 19:37 | # 2 |
Akun may have been weakened or the mars motor has failed but I can fade the presentation that 99% of the batteries have been weakened
| 08.05.2020 19:37 | # 3 |
My teacher completes the battery life ...
| 08.05.2020 19:37 | # 4 |
I thought it was from the battery, but the interior and exterior lights are on ... it just can't turn the starter motor ... the battery in my previous car 206 had changed but it didn't happen like that ... never even the lamp was lit ... May Allah be pleased with you
| 08.05.2020 19:37 | # 5 |
[QUOTE = gray wolf] I thought from the battery, but the interior and exterior lights were on ... it just could not turn the starter motor ... my previous car 206 had also changed the battery but it did not happen like that ... never even the lamp was lit ... something that is specific to 307 ... I hope the battery is Thank you. May Allah bless you [/ QUOTE] The same situation had come to the press before. As you said, the lightings burn normally or do not start. Battery replaced problem gone. |
| 08.05.2020 19:37 | # 6 |
Let me tell you the sole, the car will draw a current of about 50 amps at the time of the first star, but it will sound at the values below it, but it will not work, if it is weaker, the mars will not press at all, but the lamps will come on.When the battery is full, then the lights will not burn. There is a test method in the bidet sole. If the light on the headlights and contact light is seriously shortened, the battery is discharged.
| 08.05.2020 19:37 | # 7 |
As I said, the problem is 99% battery
| 08.05.2020 19:37 | # 8 |
Thank you brother .. thank you for your answers .. Erzurum -30 degrees at the moment ... whatever the battery is doing in this cold ..
| 08.05.2020 19:37 | # 9 |
God bless my brother, let me try the method you said .. Thank you very much
| 08.05.2020 19:37 | # 10 |
:) hey massallah allah help you, you don't need to change the battery by the way, fill it for 10 tl.
| 08.05.2020 19:37 | # 11 |
Thank you gardaş ... thanks a lot ..
| 08.05.2020 19:37 | # 12 |
teacher, I wonder what did you do?
