The sound of water coming from the top of the car accelerator pedal
08.05.2020 20:07 # 1
Dralp
NOTE: The radiator has changed and then antifreeze has been put in, the fan has been turned on in the car ....
The lonely friends from the front of my car, the obvious water sound that is not pre-change by the engine comes, usually when I start the gas when I first start it, it feels like it comes through the pipe as if it passes through the pipe. Would the fan turn on?
08.05.2020 20:07 # 2
talip206
Generally, if there is air in the system, water sounds.
08.05.2020 20:07 # 3
there is air if there is a sound of water in the system. There is air in your heater core and the system needs to be bled again.
08.05.2020 20:07 # 4
Dralp
The antifreeze in the system was completely drained (by pressing the water with the help of a water hose) it was put again unfortunately, it does not mean it continues ... When the sound continued, I did not retouch to avoid giving antifreeze money every time ...
