The sound of blunt
08.05.2020 19:45 # 1
Kansu
Everyone, Mrb. I am a 2005 model 307xt semi-automatic vehicle owner. A few days ago, I stopped at the red light, when I pressed the gas, the car did not go, when it pressed hard, the blunt sound came and continued. I went to the service but they found nothing. Yesterday, while taking off again, the vehicle did not go to 4 thousand revolutions, but the vehicle was just shouting. You didn't find anything you took to the master. Changed the gearbox oil, took 2 and a half liters of oil. The vehicle is doing it again while getting up. He does it at least once a day. I talked to a master in Ankara, he said, it is necessary to program him. Are there any problems before? What do you think I should do? The vehicle is also walking.
08.05.2020 19:45 # 2
usta307
My brother had a glance at the suspect, I had 307 manuals. All the gearbox group that got together the broken part one day changed the neglected skin cost negligence exploded 1400 usta307 2016-04-18 20:22:36
08.05.2020 19:45 # 3
Kansu
Unfortunately, there is no master who understands the automatic transmission. I was amazed at what to do. Is there any way to understand the failure of the transmission without dismantling? I talked to a master again, he said he can do it from the tube setting. There is no tube setting for my vehicle. But there is something like this, it does the same thing in gasoline
08.05.2020 19:45 # 4
usta307
Brother, you have to get it done after neglection and it will explode more.
08.05.2020 19:45 # 5
Kansu
Thank you for your comment. Nobody else is encountering this malfunction?
08.05.2020 19:45 # 6
These types of problems can be caused by cellonoid valves - automatic transmission brains - braking interference and electrical malfunctions. First, replace the brake sensor, a cheap part like the original 30-40 TL, then have the others checked.
08.05.2020 19:45 # 7
Kansu
There was a change in my brake, it seemed a little harder. Moreover, LPG became a very different vehicle to different gases. Tube brc brand. Do you think it is possible to do something like this from the gas setting? But he did the same with gas
08.05.2020 19:45 # 8
hikayeci
As the friend above says, if you can survive by replacing the brake sensor or solenoids, you will tear well. Otherwise they will open that gearbox. Do not open it in an unknown place. Otherwise you will be more upset.
08.05.2020 19:45 # 9
Kansu
Could there be anything to do with the brake light and gearshifts? They told me it served as a sensor
08.05.2020 19:45 # 10
hataner
Have a nice day . In my car, the same model car is in automatic gear in the d and r position, and a low voice sounds like a bee buzz from the bottom. this continues when the vehicle gets warm, not when I first start it. Search. I bought a second hand at 120 thousand and the gearbox oil has not changed. I would be glad if you could help ...
08.05.2020 19:45 # 11
[QUOTE = hataer] Good day. In my car, the same model car is in automatic gear in the d and r position, and a low voice sounds like a bee buzz from the bottom. this continues when the vehicle gets warm, not when I first start it. Search. I bought a second hand at 120 thousand and the gearbox oil has not changed. I would be glad if you could help ... [/ QUOTE]
First of all, my fellow welcome. Let me state that there is a problem with the gear changes, such as knock back. if not, do not do anything other than the gearbox oil change
08.05.2020 19:45 # 12
hataner
First of all, I thank you for your interest. There is no abnormality in my gear shifts. sometimes it makes you feel like you are slowing down in the red light but I am generally satisfied. But as I said, that voice from the bottom bored me. Well, do you have any suggestions for oil change, brand etc. anything.
08.05.2020 19:45 # 13
talip206
That sound comes from normal teacher solenoids, that sound is working :) talip206 2016-04-25 20:37:56
08.05.2020 19:45 # 14
hataner
My teacher does not come out when he first works :) When I drive in a quiet place, I feel the sound especially when driving with the window open towards summer. If you have it, I think it's not an abnormal sound
