The Sound (Click) Problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 21:11 # 1
humerus06
Hello, 5 days ago, I joined you by buying a 308 in 75 thousand. I like the car very well, but my car makes interesting sounds on rough roads, cobblestone roads or when the car flexes. I can't describe them as clicks, actually, a tougher voice. It can be called squeak or lokurt. I think it came from the back doors, and even when I sat and listened to two people, they said it was through the back doors. I am waiting for your advice on what to do and how to pass. Finally, I am also open to your expert, service, etc. advice in Ankara to assist with these issues. Thanks
08.05.2020 21:11 # 2
First of all, welcome to us. This is the first time you heard the click event on these doors. It can be from the rear shock absorber mounts, not from the doors. There is a mas peugeot when it comes to the master, and the master of abdullah assists in both parts and workmanship.
abdullah master mobile: 0537 964 58 20
08.05.2020 21:11 # 3
humerus06
[QUOTE = sonerkyl] First of all welcome to us. This is the first time you heard the click event on these doors. It can be from the rear shock absorber mounts, not from the doors. There is a mas peugeot when it comes to the master, and the master of abdullah assists in both parts and workmanship.
[/ QUOTE] Sir, thank you very much and I'll try to stop by tomorrow. An annoying sound makes you feel as if your car is playing all over.
08.05.2020 21:11 # 4
clean the door seals with silicone spray as far as I can remember.
08.05.2020 21:11 # 5
humerus06
[QUOTE = sonerkyl] As far as I remember, it is probably more likely to clean the door seals with silicone spray [/ QUOTE] Brother I tried it about 1 hour ago with wicks, I passed through most places with silicone spray. Let's see if it will help. If I don't try tomorrow morning, I'll stop by
08.05.2020 21:11 # 6
recepagdas
Did you have a problem with the silicone spray?
08.05.2020 21:11 # 7
mesut_k61
I took it to the service, because of these sounds, there was a spray spray, they squeaked, I don't remember its name, but there is a wurth silicone spray on the internet.
08.05.2020 21:11 # 8
Mtepe
[QUOTE = humerus06] Hello 5 days ago, I joined you by buying a 308 in 75 thousand. I like the car very well, but my car makes interesting sounds on rough roads, cobblestone roads or when the car flexes. I can't describe them as clicks, actually, a tougher voice. It can be called squeak or lokurt. I think it came from the back doors, and even when I sat and listened to two people, they said it was through the back doors. I am waiting for your advice on what to do and how to pass. Finally, I am also open to your expert, service, etc. advice in Ankara to assist with these issues. Thanks [/ QUOTE]
Usually, these kinds of sounds come from the amartisor wedge, but you can still change them without being sure.
