The sound after the pits ??
08.05.2020 15:24 # 1
eserxxx
Hello guys, I have a 2003 model 2.0 HDI 307, I caught my attention recently, even if I put the car in small pits, bumps, as soon as I hit the gas, it sounds like a tin can, as if rubbing something. The sound stops immediately, even without a second. I thought it was a fender from the beginning, but I was careful, it was just the level of the front seats, the sound coming from the bottom .. I am afraid of the transmission problem.
08.05.2020 15:24 # 2
elbu
Get well, the brake pad is loose from what you told.
08.05.2020 15:24 # 3
xdesign
Elbu mate, we would appreciate if you introduce yourself first.
Eserxxx dude is either from brake discs (including pads, calipers, etc.). But if it cuts in 2 seconds, there may be a stone or something stuck. Sometimes it happens to all of us. Transmission is not a job.
08.05.2020 15:24 # 4
metin
[QUOTE = eserxxx] Hello guys, I have a 2003 model 2.0 HDI 307, it caught my attention recently, even if I put the car in small pits, bumps, as soon as I hit the gas, it sounds like a can from the bottom, as if rubbing something. The sound stops immediately, even without a second. I thought it was a fender from the beginning, but I was careful, just the sound of the front seats, the sound coming from the bottom .. I am afraid of the transmission problem [/ QUOTE]
There are no transmissions under the front seats, there are two anti-roll bars.
I was doing it while passing through the set.
08.05.2020 15:24 # 5
eserxxx
The front brake pads and discs did not change for 1 week, so I don't think it was from the brake assembly, which was before the change, that sound, but I didn't care. It just caught my attention, it only happens when I get into speed humps and small pits. You said the bending iron tires Metin Bey, I don't know the shape of that piece, but the sound coming is not like the plastic sound, it is a sound like a rusty tin rub. I took it to the master, but the vehicle was afraid of the master, I guess, no matter how far I got into the pit :) I left the master back, just like I turned around the corner. the sound that I don't care about.
08.05.2020 15:24 # 6
flash296
look at the exhaust pipes. Lift to lift ... there is a definite gap hitting it as it shakes!
08.05.2020 15:24 # 7
MemoTech
You can come from the tables or swings. If it is a Z rot, it sounds like a lacquer. MEMOTECH 2011-05-15 19:45:09
08.05.2020 15:24 # 8
metin
eserxxx hello. The piece I showed in the painter is virgin iron, it is connected to the rods from there to the shock absorber, where there is a number 2 piece, i.e. bend iron tires, in the places where this iron is enclosed round.
The number 3 is mounted on the chassis of the vehicle and the bend iron tire (2) comes to the bed, and the anti-roll bar passes through the tire. When these tires pass through water, dust, water, car sets, etc., the garlic makes a sound of sound, I did not change it, the oil that I lubricated went away from time to time, but I will change it at the first opportunity.
08.05.2020 15:24 # 9
boranaydogmus
In my opinion, look at the exhaust.
08.05.2020 15:24 # 10
eserxxx
A friend found the solution to the situation by chance. The sound that I thought came after the pits came after braking. I took it to the master, he said that the ABS motor works out loud. It doesn't cause any problems in the short term, but when the ABS lamp comes on, he told me to bring the car to him. Thank you all for your help, I wish you an accident-free ride
08.05.2020 15:24 # 11
metin
[QUOTE = eserxxx] A friend found the solution by chance. The sound that I thought came after the pits came after braking. I took it to the master, he said that the ABS motor works out loud. It doesn't cause any problems in the short term, but when the ABS lamp comes on, he told me to bring the car to him. Thank you all for your help, I wish you an accident-free ride [/ QUOTE]
Have a good problem, get well soon.
You can still take action early, which may incur greater costs later on.
08.05.2020 15:24 # 12
tayfundoner
[QUOTE = text]
Yes, I definitely agree. In a pit in our partner, we were making it sound like we were going to be disturbed. As the iron element said, the tires of the iron are gone, the iron that keeps it in the bidet has changed, no more sound or click.
