The solution to the 307 horn hard press?
08.05.2020 14:07 # 1
ozgurkso
Friends 307's horn makes me nervous because it pushes me too hard. I know the original is hard but if we disassemble and review the steering hub, is there any possibility to find a solution?
08.05.2020 14:07 # 2
ozgurkso
Is it enough to remove the two screws on the back for steering hub removal?
08.05.2020 14:07 # 3
bbcb
disassembling the steering hub requires good mastery airbag signals are completely dismantled, you look at the horn itself and its role and if they don't come out, there is a contact in the hub
08.05.2020 14:07 # 4
hasimayaz
Peugeot 307 Horn Oxidation Removal.
First, we removed the Ignition key. We remove the battery terminals.
By pushing the airbag lock forward with an appropriate sized flat screwdriver, we ensure that the airbag comes out. At this point, we have to be very careful, we will need some strength from the outside, we have to support the release of airbag with your other hand. Lock springs must not be damaged. We must adjust our strength well, neither too much nor too little.
The red arrow shows the spring pushed by the screwdriver, the blue arrow locks holding the airbag, the Blue arrow shows the horn chassis.
We carefully remove the chassis socket.
Let's clean the chassis connection and the contact points of the horn with fine nail file or 0 number sandpaper.
Let's stretch the chassis socket a little and grease it with contact grease. Contact Cleaner can help us with the spray.
08.05.2020 14:07 # 5
ozgurkso
Very useful information, thank you.
08.05.2020 14:07 # 6
hasimayaz
http://forum.peugeotturkey.com/forum_posts.asp?tıd=7290&pıd=102456#102456
We fixed it on how it is done. Against the death of pictures
08.05.2020 14:07 # 7
ozgurkso
Today I removed the steering wheel, clean the contacts and apply grease, the horn has recovered a bit. It is not a difficult task, but you need to be careful.
